1 members (TexasJim50), 119 guests, and 2 robots.
Topics128,265
Posts1,058,364
Members48,485
#232572 04/24/2007 7:45 PM
I have just gotten my new lower A arm shafts and am in the process of installing them as the old ones were bad. I have them loosely hun by the "U" bolts and would like to know the procedure for getting the large end bolts adjusted so I can take it to a shop for proper alignment. It seems they get tight on the arm before the shafts and seals are tight.
Any sugestions? I appreciate this.
Gary in Mich.
GS
#232573 04/25/2007 4:09 AM
My truck doesn't have A arms. You should post what year and model yours is.
#232574 04/25/2007 12:13 PM
Sorry. This is a '66 fleetwood that I am putting in new suspension but can't figure out how to adjust the large nuts on the ends of the A arm rods. These are the ones with the grease fittings on the ends.
GS
#232575 04/25/2007 1:58 PM
A fleetwood is a Cadillac-you must be working on a fleetSIDE? Just picking on you-the shaft should be centered in the A-arm, the book shows a distance of 3/4 inch between the edge of A-arm & the seal surface of the shaft, the bushings need torqued to 125-140 ft/lbs. I used an air impact, of course. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#232576 04/26/2007 4:11 PM
OK,I can center the shaft, but do you hold the shaft when you torque it? nothing to grab except with channel locks. The inside of the nut threads into the shaft. It seems you tighten the big nuts to the A arm and then can move the shaft as well.
I appreciate the help.
G.
GS
#232577 04/26/2007 4:24 PM
It seems I put a big pair of channelocks on them also, you want the shaft to stay centered. The shaft should move when done, but it will be stiff.
#232578 04/26/2007 7:50 PM
OK but how can the shaft move if it is tightly attached to the frame by the U bolts? The U bolts go around the shaft. Hmmmmm
GS
#232579 04/26/2007 7:54 PM
The shaft moves inside the bushings.
#232580 04/26/2007 8:01 PM
I guess I better go out and look at it again. is there an inner shaft that moves? since the shaft I see is u bolted to the frame solid.
GS
#232581 04/26/2007 8:12 PM
If nothing moved, what would happen when you hit a bump? Perhaps rotate is a better term, the shaft must rotate when you are finished.
#232582 04/26/2007 8:32 PM
Thanks a lot. Now I get it. Good explanation. I guess I am a little dense.
GS
#232583 04/29/2007 3:44 PM
Quote
check his profile...66
#232584 04/29/2007 8:56 PM
I believe people should include what truck with their question. I don't think it should be neccessary to check the profile of the poster of every thread you open. And what if you did open it and find out the guy has a '42 and a '52? ohwell
#232585 04/30/2007 2:22 PM
Quote
Well, I assumed since he said lower a-arms we were dealing with a 60-72, since he is dealing w/a lower shaft(not a torsion bar) that narrows it to 63-72, & all those use the same lower arms & mounting setup.
