8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#23236 10/19/2002 6:14 PM
Tab
Offline
I have a 62, 3/4 ton Chevy P/U. I read the lengthy article about installing a T5, S10 5sp trans behind a 235 but I still have a few questions. I'm going to the swap meet in Arlington, Tx next month and I want to make sure that I buy the right trans. When I find a guy who shows me his wares how do know if it is right for my application? I'm mainly concerned about shifter position (bench seat) and bolt patterns. I would prefer a later model T5 trans. Is there a way to tell from which year/truck the trans came?
delete my account and pictures
This topic inspired me to finally post some info that Kinky6 and I have been collaborating on forever. This list may not be complete, but it's a start. It includes the NWC T5s from 1980's S10s and minivans. If looking at a T5 at a swap meet, these numbers can be a big help. If the seller knows the source of a particular T5, all the better. Hope this is of some help. Please remember that this page is a work in progress. Feedback, corrections and updates are welcome.
T5 Tech
Tab
Offline
Thanks for the reply. What is the link to this info?
Whoops sorry...brain f**t. Link should be appearing now.
Tab
Offline
Link? Hmmmmmmm? Set your beer down and try again......
Nice writeup Jack, thanks. smile
Buzz'n Half Dozen
Tab
Offline
Can you please post the link?
The link has been there since 4:49 PM yesterday...Look at the edited post.
Junior Member
Junior Member
Great info. Stupid me, I looked on the chart and saw mine was out of an 83 s10 with the .86 overdrive instead of .72 overdrive, which is what my seller told me. Anyway, is there any way to replace the overdrive gear I have already with a new one (.72 od)? Is it just a matter of replacing the assorted gearsets for 5th gear to make it .72 od? I'm already in there overhauling it
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!)
1950 Ford 2 door sedan-project
Tab
Offline
I reloaded the page. Still no link....I launched a differnet browser...Still no link. Can someone please just send the link to me at [email protected]
Anonymous
Unregistered
Anonymous
Unregistered
Tab . . .
click HERE
and if that didn't work, cut and paste http://www.inliners.org/Jack/t5_page.html into your browsers address window and have a look.
Nice job 6pack and kink
Thanks for taking the time and effort to do all that. Im not much of a mechanic but your simple no BS approach to writing is understandable and inspires that I could do this with some help. Cheers.
Send David Hicks home - now!
"Better to be wrong and kill no one then right with mass graves" Albert Camus
Tab
Offline
Excellent. Thanks for the info. For the life of me I don't know why that link didn't show. I tried two browsers.
It must be a coincidence because I live in the DFW area and plan to move to Florida just N of Winterpark where I once lived. If you guys see a Glenwood Green 62 Chevy 3/4 ton step side on the road with a guy and a dog inside give me a wave.
http://www.stovebolt.com/gallery/ballard.htm
Hey, 63jalopy, the fifth gear cog is located in the tailshaft housing on the T5 trans, so you might be able to swap out the .86 gear for the .72 gear, as long as it will mesh with the output shaft. If not, you may have to get an output shaft with the correct gear.
Hope this helps. Kinky6.
< Passin' Side ........ Sui-Side >
63jalopy,I just put together a hybrid Camaro-S-10 and it looks like you could just switch the overdrive gears to go to a .72 OD ratio. You would need to switch both the gear on the mainshaft and the one on the countershaft. I've seen most of the gears for sale new if you have plenty of money. Might be better to find a used tranny for parts.
I took a different aproach to the speedo gear on my hyrid than Jack and put the Camaro gears on a S-10 mainshaft. Not all of these gears come off as easy as others and I had to bring some parts to a tranny shop to have them pressed off, my gear puller just would not work on one. I also found two bad countershafts when dissasembling trannys for parts. The NWC T-5 doesn't use bearing races on it's counterhshaft, so if there is any wear here your countershaft is trash. For this reason when looking for a tranny I would spin it and listen for a bearing noise in the lower part of the tranny. If you hear a noise I would consider this box for parts, not worth much more than $50.
Does anyone know if the WC t-5 fits the same as the NWC? Remember seeing a post about them being on a angle. Also anyone know if the wc box uses bearing races on the coutershaft?
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
