7 members (dt235sd, Cosmo, jeffreyguy, Otto Skorzeny, Charles in CA, LAROKE, Wally / Montana),
137
Mod | | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | I just posted pix of the Cab bottom Line-X job. I'm really pleased with the finished product and plan on doing the floor board, fenders, and running boards. Will post those pix when completed. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | That's pretty swexy, Don. I can't see that puppy rusting any time soon.  | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 |
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Is Line X any different from Rinoliner?
~Jim
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | I think they are basically the same product although you might want to check with your local dealer. After all of the expense of restoring this viejo truck I think the Line-X is a good way to preserve it, especially here on the beach. The Line-X is not cheap by any stretch but it's almost indestructible and I like the look better than some of the gooey products.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | That looks really good. Nice work!! | | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | I used Line-X on the inside of my bed sides, step in cab and step in front of rear fender. I like it. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i used the spray on rubber coating under everything 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | It looks great, when I redo my floor panels I will probably use it as well... would it be possible to get a panel covered before you weld it in ,f you leave a spot of bare metal to weld or not?
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Mike - I don't see why not. These guys removed a panel from the gate on my F250 and redid it while doing the '41 cab. I don't know how much heat propagation your welding would produce and its effects on the lined panel. Let us know when you try it.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | How about the inside floor of the cab? I am seriously considering it for my 48. On the 48 I am sure I will do the underside of fenders, cab, and running boards.
I have another project truck I think I will experiment with it on the cab floor and as far up the firewall as possible. I have been trying to decide if it is a good idea to put down some of the thin sound deadener like dynomat on the floor, and then the bed liner over that. Right now I think it may be a bad idea because it could leave a place for water to hide, if the bed liner is bonded to the steel itself then no water. So do you sandwich the sound deadener between two layers of bed-liner, a thin one, dynomat, and a thick one? I know the bed-liner will help quiet the cab a lot by itself, but I have Detroit diesel two strokes in both trucks, so they can use all the help they can get on sound deadening.
What do y'all think?
Grigg | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | That stuff will burn if it's anything like Rinoliner. I had a 2004 250 diesel that caught fire in the bed (Rinoliner) and burned up the whole truck. I think I'll have the undercarriage done and the firewall with that stuff.
~Jim
| | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | I will look for the article... someone did an analysis of this material and dynamat, they are the same, this stuff was a fraction of the cost... it is in one of my old skool rodz mags a while back... I will find it and post it, save you guys some dough..
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Mike, Did they consider using both for more sound deadening? I wonder if there is a noticeable difference in using both, or is it the same as with a one good thick coat of bed liner?
Right now the truck has about 1/2" of regular house carpet padding and some green ugly fuzzy carpet. I wonder what the difference will be in that and the bed liner. I hope there is a big difference, because it is a bit loud already.
Grigg | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | they discovered that the material in question was exaclty what dynamat is... it's just cheaper... I will try to find the article tomorrow..
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Big Chevy 3600 wrote Is Line X any different from Rinoliner? This afternoon I parked my F250 next to an identical truck. My truck has the Line-X bedliner and the other had the Rinoliner. I can truly say, without bias, that the Line-X is a much nicer looking application. The Line-X is much smoother and uniform looking. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | For a while I thought Line-x was the best of the bunch. About 2 years ago my Dad had the bed in his new truck coated with "Reflex" brand stuff because they have a local place. I don't know if it is any better or worse than line-x, but it looks great after 2 years as a work truck, and is at least as good in my opinion. I think that the line-x looks a little porous, not that it is, but it has a kinda sand paper look to it. The Reflex stuff has a non porous look, yet it still has a fine lumpy texture and stuff won't slide on it. I think it looks a bit better than line-x because it may be easier to clean, as dirt won't stick to it as much? Anyone noticed these differences too?
They have a sample at the shop that is about 3/16" thick, and not stuck to anything, just the black stuff. It was cut from a larger sheet and you can't see any air bubbles in the edges. It is very rubber like, a bit harder than an inner tube, but softer than most tires. It seems perfect for the undersides of cabs, fenders, and as a floor mat. I have only seen line-x with it stuck to something, so don't know how it compares for rubberyness and air bubbles
Grigg | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Down2sea,
What did they charge you for this? I was getting rough quote for mine and the wanted $400. | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | $307 including the 6% sales tax. Not cheap but I think it will be worth it for the long haul coming up towards the end of summer. My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | |
