6 members (Otto Skorzeny, Charles in CA, BarryP, BC59, tclederman, 1 invisible), 98 guests, and 3 robots.
Topics128,140
Posts1,056,771
Members48,454
Junior Member
Junior Member
I have yet to see or get an explaination of how to wheather strip around the doors on my 46. I bought the stuff months ago, but still dont know how to install it.
If you have pics of an instalation or any info, I would apreciate it.
Email to [email protected]
Thanks as allways
have you checked out this website?
http://alanhorvath.com/54chevy/doorubber.php
Its on a 54' Chevy but its about the same
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
If you use the search feature you will see quite a lot of information on this. Try the link below.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi
~Jim
Junior Member
Junior Member
Thanks for that.
Duh. It glues on. no wonder I couldnt find any holes or clips in the catalogs.
I have the stuff, I can do that.
Junior Member
Junior Member
I tried the search feature, it didnt work for me. I will try it again, thanks.
The '54 truck door weatherstrips are totaly different from Art Deco trucks. There should be some metal molding holding the weatherstrip in place. Like these on my '45:
pic 1
pic 2
Z
Z Offline
They do not glue in. The trim pieces around the door hold it in place. If you buy repros (I bought the rubber ones) you will just poke holes in it to make it easier for the screws to pop through as you are trying to put the trim back on.
1946 Chevy Pickip
Junior Member
Junior Member
OK I see the holes and understand the system now. I dont have those trim pieces.
I have the rubber. Did you mean the metal trim is available in a repop?
Thanks you guys are a ton of help, as allways.
Z
Z Offline
I meant that the seals are available as repros in rubber or vinyl. You can put a post in the parts wanted section or check ebay for the trim pieces. These trim pieces go all around the inside of the door.
1946 Chevy Pickip
Junior Member
Junior Member
Hey zipper, I looked at the pics of your truck, good job. It will look off the chart when finished like the last pic in satin black.
I am going for much the same look.
