| | | Forums66 Topics128,192 Posts1,057,351 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | What is the tube that protrudes from the firewall into the engine bay for? It has two places for what looks like the heater hoses to attach to. My 51 3100 has the heater hoses going through the firewall via the grommets and into the heater, should one of them go to the heather then to this thing sticking out of the firewall and then one out to the water pump? What does it do?
Thanks in advance for your help. | | | | | Joined: Mar 2007 Posts: 22 New Guy | | New Guy Joined: Mar 2007 Posts: 22 | | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | Do you have fresh air heater or do you have a recycle heater | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | This might be a silly question, but do you have a temperature control knob that says warmer? If I am picturing what you are saying that is the heater control valve which controls the flow of the water into the heater core. Is your truck bypassing that valve somehow? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | The tubs that protrude from fire wall is a heat regulator. On then in side of cab should be a handel comeing off of this to under the dash so you can control the hot air. Mine has been down for some time so I hope I get this right, the hoses run like this. from the heater to the top of thermostat, then from the water pump to the regulator, then from the regulator to the heater | | | | | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | Thats it Super! It has the handle that says "warmer" inside the cab. I wonder why the Previous owner bypassed this? The hose just bypassed it totally and and just went into the heater inside the cab. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Maybe the regulator is leaking. You can replacements at just about any of the parts guys on the links at this site. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They were real bad about leaking (gushing). The quick fix was to bypass it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
