2 members (Hotrod Lincoln, 1 invisible), 156 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#232203 04/19/2007 5:17 AM
What is the tube that protrudes from the firewall into the engine bay for? It has two places for what looks like the heater hoses to attach to. My 51 3100 has the heater hoses going through the firewall via the grommets and into the heater, should one of them go to the heather then to this thing sticking out of the firewall and then one out to the water pump? What does it do?
Thanks in advance for your help.
#232204 04/19/2007 5:24 AM
got a pic?
#232205 04/19/2007 5:43 AM
Do you have fresh air heater or do you have a recycle heater
1951 Chevy 3100 Deluxe 5-window
Four generations and still not for sale!
More pictures in Photobucket
David
#232206 04/19/2007 5:50 AM
Big Bolt Forum Co-moderator
This might be a silly question, but do you have a temperature control knob that says warmer? If I am picturing what you are saying that is the heater control valve which controls the flow of the water into the heater core. Is your truck bypassing that valve somehow?
1948 Chevy 2-Ton
#232207 04/19/2007 5:56 AM
The tubs that protrude from fire wall is a heat regulator. On then in side of cab should be a handel comeing off of this to under the dash so you can control the hot air. Mine has been down for some time so I hope I get this right, the hoses run like this. from the heater to the top of thermostat, then from the water pump to the regulator, then from the regulator to the heater
David
#232208 04/19/2007 2:48 PM
Thats it Super! It has the handle that says "warmer" inside the cab. I wonder why the Previous owner bypassed this? The hose just bypassed it totally and and just went into the heater inside the cab.
#232209 04/19/2007 2:58 PM
Maybe the regulator is leaking. You can replacements at just about any of the parts guys on the links at this site.
1948 Chevy 2-Ton
#232210 04/19/2007 8:54 PM
Riding in the Passing Lane
They were real bad about leaking (gushing). The quick fix was to bypass it.
1972 Chevy c10 Cheyenne Super
