2 members (crenwelge, 1 invisible),
181
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | What are hazards or probs with stainless steel brake lines. Now that i own a set. :rolleyes: | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | It depends on the heat treatment. Annealed lines are softer, less prone to cracking when bent, and can be flared if needed.
Fred 52 3600 69 C-10
#2318 11/04/2003 10:46 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Follow the directions closely, that will help you get them to make a seal when installing.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Biggest danger is not getting full points in an authentic restoration review at Carlisle. :rolleyes: | | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Hey Ken, Weren't you going to dabble with your SS lines this past weekend?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Craig - they have not shown up yet. It is on my list to call this week and find out what is up. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | The only problem I had was getting them to seal. Had to loosen and tighten a few times and really torque down on the fittings, so much so I was afraid of stripping,breaking them. | | |
#2323 11/05/2003 12:32 AM | | Anonymous Unregistered | | Anonymous Unregistered | brjr51 - who did you buy your lines from?
craig - big box showed up today - plan is getting two trucks done on Sunday, I'll let you know how it goes. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Ken, I bought mine from Inline. Was happy with them. | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Did you guys order already made to fit or make them up? I really think I can do it myself. popcorn The Truth is Out There (Inquirying mind would like to know) | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Thanks brjr51 - 6 kits w/clips showed up from Fed-X today - early Christmas for a handfull of bolters. We pooled our resources and got 15% off of normal price + shipping for 6 sets was the same for a single set, so I think we did ok.
Pops - all pre-bent, pre-flared with nuts and plastic caps ready to go. | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Ken Thanks: let me know how it turns OUT. be a good thing to start while the frame is just sitting there. pops The Truth is Out There (I love this page) Thanks again | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Gee thanks for the heads up on stainless guys. AND TO KEN, What are the six sets of lines going into? IF there is a 46 truck in the bunch could you or the owener check to see if IN the pass side tube that goes to the frame clip then to wheel and see if there is a rust red powder in it.  This tube is a very tight bend and is almost a full circle . mine had this powder in it. IM HOPEING that the powder is used to keep the tube from kinking when bent because of the small radius of the bend. Has anyone seen this in any other tubeing bends. :confused: | | | | | | Anonymous Unregistered | | Anonymous Unregistered | All chevy 3100's ranging from '49 to '53 (pickups and suburbans).
Note - the '49s and '50s have 1/4" lines and the newer trucks have 3/16" lines. Not all are this way so you have to double check. | | |
