1 members (Bucker), 144 guests, and 2 robots.
Topics128,196
Posts1,057,391
Members48,471
What are hazards or probs with stainless steel brake lines. Now that i own a set. :rolleyes:
It depends on the heat treatment. Annealed lines are softer, less prone to cracking when bent, and can be flared if needed.
Fred
52 3600
69 C-10
Follow the directions closely, that will help you get them to make a seal when installing.
Anonymous
Unregistered
Anonymous
Unregistered
Biggest danger is not getting full points in an authentic restoration review at Carlisle. :rolleyes:
Hey Ken,
Weren't you going to dabble with your SS lines this past weekend?
Craig
Anonymous
Unregistered
Anonymous
Unregistered
Craig - they have not shown up yet. It is on my list to call this week and find out what is up.
The only problem I had was getting them to seal. Had to loosen and tighten a few times and really torque down on the fittings, so much so I was afraid of stripping,breaking them.
Anonymous
Unregistered
Anonymous
Unregistered
brjr51 - who did you buy your lines from?
craig - big box showed up today - plan is getting two trucks done on Sunday, I'll let you know how it goes.
Ken, I bought mine from Inline. Was happy with them.
Did you guys order already made to fit or make them up? I really think I can do it myself. popcorn The Truth is Out There (Inquirying mind would like to know)
Anonymous
Unregistered
Anonymous
Unregistered
Thanks brjr51 - 6 kits w/clips showed up from Fed-X today - early Christmas for a handfull of bolters. We pooled our resources and got 15% off of normal price + shipping for 6 sets was the same for a single set, so I think we did ok.
Pops - all pre-bent, pre-flared with nuts and plastic caps ready to go.
Ken Thanks: let me know how it turns OUT. be a good thing to start while the frame is just sitting there. pops The Truth is Out There (I love this page) Thanks again
Gee thanks for the heads up on stainless guys.
AND TO KEN, What are the six sets of lines going into? IF there is a 46 truck in the bunch could you or the owener check to see if IN the pass side tube that goes to the frame clip then to wheel and see if there is a rust red powder in it. eek This tube is a very tight bend and is almost a full circle . mine had this powder in it. IM HOPEING that the powder is used to keep the tube from kinking when bent because of the small radius of the bend. Has anyone seen this in any other tubeing bends. :confused:
Anonymous
Unregistered
Anonymous
Unregistered
All chevy 3100's ranging from '49 to '53 (pickups and suburbans).
Note - the '49s and '50s have 1/4" lines and the newer trucks have 3/16" lines. Not all are this way so you have to double check.
