8 members (FAST55, Wally / Montana, Wickedbass, Mike Burns, Gdads51, Donf, 55shaker, Ponchogl), 75 guests, and 4 robots.
Topics128,065
Posts1,055,868
Members48,428
#232008 04/17/2007 2:12 PM
Yesterday I had to cut open the front of the drivers door to replace the front part of the hinge mount which had rotted away. It was a bit of delicate surgery working through a small hole but successful. The door is much more stable now and actually closes and opens.
On another note I removed the set screws on the door handles and window cranks but cannot get them off. Before I wreck something does any one have any tricks to remove these???
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
Anonymous
Unregistered
Anonymous
Unregistered
You say you removed the set screws but if they are not all the way out then they might still be preventing the handles from coming off. If the screws are totally removed it might take some gentle force (rubber mallet) to break the hold they have on the crank axle.
rust bucket 53,
Make sure there isn't a second set screw that was underneath the first. Sometimes the top screw is used to jamb the bottom one to keep it tight.
Stuart
Sorry Stuart, I was not clear. The set screws came right out but the handles wont budge.
I have soaked with WD 40 but you cannot really soak them except throught the set screw hole.
I dont want to wreck my window regulator or latch release.
Should the handles come off easily once the set screw is removed. All 4 of mine wont budge. Am I missing some other fastener?
1953 3/4-Ton Chevy
More pix
RB53
Thanks Guys I will check the set screw holes and use soem gentle persuasion
1953 3/4-Ton Chevy
More pix
RB53
Those handles should have two screws in them. The top screw is just for appearance and the one underneath actually contacts the shaft.
1951 1 Ton Completed
truckernix,
I have to admit I thought you were nuts when you said they had an inner and an outer screw. but low and behold you were right. That's not even in the manual.
Thanks for sving my sanity. I never would have thought to look in those holes.
1953 3/4-Ton Chevy
More pix
RB53
Don't feel bad, I did the same thing. Just a few seconds before I was about to use some persuasion from the 'blue tipped wrench' I discovered the second set screw. Why they used a second screw is beyond me, but they did.
"If it ain't broke, I haven't gotten ahold of it yet!"
'51 Chevy 1/2 Ton 5 window
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
One VERY understanding wife
http://community.webshots.com/user/51rustbucket
All's well that ends well!!!
~Jim
