2 members (artinva, Chip O),
112
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Yesterday I had to cut open the front of the drivers door to replace the front part of the hinge mount which had rotted away. It was a bit of delicate surgery working through a small hole but successful. The door is much more stable now and actually closes and opens.
On another note I removed the set screws on the door handles and window cranks but cannot get them off. Before I wreck something does any one have any tricks to remove these??? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | You say you removed the set screws but if they are not all the way out then they might still be preventing the handles from coming off. If the screws are totally removed it might take some gentle force (rubber mallet) to break the hold they have on the crank axle. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | rust bucket 53,
Make sure there isn't a second set screw that was underneath the first. Sometimes the top screw is used to jamb the bottom one to keep it tight.
Stuart | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Sorry Stuart, I was not clear. The set screws came right out but the handles wont budge.
I have soaked with WD 40 but you cannot really soak them except throught the set screw hole.
I dont want to wreck my window regulator or latch release.
Should the handles come off easily once the set screw is removed. All 4 of mine wont budge. Am I missing some other fastener? | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Thanks Guys I will check the set screw holes and use soem gentle persuasion | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Those handles should have two screws in them. The top screw is just for appearance and the one underneath actually contacts the shaft. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | truckernix, I have to admit I thought you were nuts when you said they had an inner and an outer screw. but low and behold you were right. That's not even in the manual. Thanks for sving my sanity. I never would have thought to look in those holes. | | | | | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | Don't feel bad, I did the same thing. Just a few seconds before I was about to use some persuasion from the 'blue tipped wrench' I discovered the second set screw. Why they used a second screw is beyond me, but they did. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | All's well that ends well!!!
~Jim
