1 members (Steveoreno), 111 guests, and 2 robots.
Topics128,195
Posts1,057,375
Members48,469
#231396 04/09/2007 4:15 PM
kwf
Offline
Just bought a '64 GMC, model 1502. It's a 3/4 ton with 15" 8 lug split rims! What would be a good replacement wheel? I would like a 16" wheel that was stock appearing yet accept the stock hubcaps. Is there such a wheel?
#231397 04/09/2007 5:09 PM
Yes. Plenty of 'em. Check your local used parts suppliers.
1951 3800
-hotshoe
#231398 04/09/2007 8:29 PM
kwf
Offline
Thanks hotshoe!
#231399 04/10/2007 8:00 PM
I retrofitted the wheels on my 1950 3/4 ton and bought a set of 8-lug wheels from a 1990 Suburban. They are 16" x 6-1/2" I paid $80 for a matched set of 4. Installed BF Goodrich Commercial T/A's 215/185/16 LT/s. They look kind of old school with no white stripe or letters.
#231400 04/11/2007 9:39 AM
brad, are you using alloy wheels or steel? are you running a spacer to make up for the positive offset?
#231401 04/11/2007 2:40 PM
I am not using wheel spacers, the wheels are steel and I modified my tie-rods and steering arms to fit, i now have about 1/4" of clearance between the wheel and the tie-rod ends. These wheels have exactly 3/8" inch difference from the ones that were on it which I am not sure were originals since they were 15" splits on the front and 16" splits on the back. I gained almost 1/2" per side by getting away from the old tie rod ends. I bought a new tie-rod and ends but I am going to go the speedway route and retrofit a new custom tie-rod and ends also new drag link same style from them.I drove the old studs out as others have suggested by grinding off the nut side and drilling out the center, they then popped right out.
