| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23133 12/07/2004 2:58 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Should I be worrying about this?
I am switching manifolds on a 235 ci Chevy from stock to Offy 2x1. The engine sits at a 4 degree tilt to the back. The stock intake carb mounting flange sits at 0 degrees I surmise so the fuel is level in the bowl. The aftermarket Offy 2x1 appears to not have this offset so when bolted up to the head the carb mounting flange will have a 4 degree rear tilt just like the engine. My question ~ should I compensate by adjusting the fuel level in the carbs? I will be using 1 bbl Stromberg BXOV-26's? I thought about sanding down the carb insulators to give "0" degrees when mounted. Recommended fuel pressure is 3 lbs.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#23134 12/09/2004 10:25 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | Good question. I was thinking about the same problem (dual Weber/Holley - Offy setup) because of the heavy duty oilbath air filters I have. I wonder if they do ther job so well if they are tilted.
My plan is to grind the adapters that connect the offy and the carbs to get the right angle.
Frank | | |
#23135 12/11/2004 12:56 AM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Four degrees is probably not going to be a problem (did you ever drive up or down a hill with more than 4 degrees?). Of course I can remember Dad talking about having to back up steep hills with the Model T (gravity feed) as it would run out of gasoline!
Some of the marine suppliers do have adapters, but I believe they are in the 10~12 degree range.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
