5 members (Gray_Ghost, baldeagle, Forty9, Hush, tclederman), 66 guests, and 12 robots.
Topics128,020
Posts1,055,345
Members48,419
#231278 04/07/2007 9:07 PM
I replaced the original ring and pinion with a 3:55.1 in my 1952 GMC (248) from Patricks so I could drive highway speeds. I had to rebuild the trans after the syncro went out. I'm using the reducer gear that Patricks sold me to help with the speedometer. Now the speedometer is way off. The more I drive it for a day the worse it is. Any ideas what I can do besides replace my cluster package. The cluster package was new when I restored the truck.
Larry Wilke
1952GMC 101
1959 Edsel Ranger 2DR and 1956 Dodge Lancer Custom Royal (in progress)
#231279 04/08/2007 12:18 AM
Ex Hall Monitor
Ex Hall Monitor
Any good speedo shop should be able to adjust your speedo for you. Just determine how far off it is & let the shop know. If you don't have a speedo shop close by there are several that advertise in Hemmings Motor News.
#231280 04/08/2007 12:39 AM
The difference changes the more I drive each day. Some times the speedo shows "0" until I shift to second gear.
Larry
1952GMC 101
#231281 04/08/2007 1:23 AM
Has the speedometer ever worked since you installed the reducer gear? Is the reducer gear external to the tailhousing? If so, did you try running the speedo cable straight to the trans, bypassing the reducer? That would help verify that it isn't in the speedo head.
The speedometer gears in the tailhousing are often damaged when the tailhousing is attached to the transmission.
#231282 04/08/2007 2:47 AM
the speedo has not been worked on since I installed the reducer gear. When I get back to Michigan I will try without. I'm in Arizona until the fisrt part of May.
Larry
1952GMC 101
#231283 04/08/2007 2:48 AM
Should I try installing the reducing gear directly to the speedo and not the trans?
Larry
1952GMC 101
#231284 04/08/2007 3:17 AM
That would be a question for Patricks, what did the instructions say?
#231285 04/08/2007 3:40 AM
sounds to me that the reducer or trans gear is slipping.
Welcome to the bolt larry, visit often.
Wilbur
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#231286 04/19/2007 10:42 PM
Apprentice
Apprentice
I had the opposite happen. The speedo needle on my '54 would frequently fluctuate back and forth in a 20-30 mph range. I had a Patrick's 3:55 kit installed this week, along with the speedo gear set that he sells, and now the speedometer is spot-on and very stable. I had my wife pace me on the interstate yesterday and the 54 showed the identical speed as my 07, right up to 75 mph. (The 3:55 made a HUGE difference in the truck, as it will easily cruise at highway speeds, and the engine noise was noticeably reduced.)
#231287 04/20/2007 6:00 PM
The square hole in my speedo had rounded and the square end of the cable would slip, catch up and slip again. It was wild.
I enlarged the square cable end a bit with some epoxy and a file. I then made sure I didn't did screw it into the speedo too tightly. That can cause problems. It's now perfectly smooth.
#231288 04/20/2007 6:06 PM
Have you checked the cable/gauge with an electric drill? That'll tell you if your cable is bad or if your speedometer is shot.
My money's on the reducer or the drive gear.
Also, there's a speedometer place in Pontiac called Scott Speedometer . Not too sure where you are in Michigan, but they seem to be pretty good.
Welcome aboard!
