1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23125 07/04/2002 6:38 PM | Joined: Jul 2002 Posts: 17 Junior Member | | Junior Member Joined: Jul 2002 Posts: 17 | I want to install a H.E.I. onto My 261 anybody done that and could help out with any info
48 nick
#23126 07/05/2002 4:11 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Tony has done it on his Stovebolt........I am sure he will be right along to explain it in detail........
*** GMC ***
#23127 07/05/2002 11:52 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Ok, I wasn't gonna answer this, figured some one of the other guys would. I did a bunch of these, removed the flange from the distributor body with hack saw and file, shortened the end of the distributer shaft about 3/8 of an inch and dressed the shaft end with a file.The hold down is home made.Its esay to do, just compare the old and new distributor shaft length carefully. modified HEI body | | |
#23128 07/06/2002 5:25 AM | Joined: Jul 2002 Posts: 17 Junior Member | | Junior Member Joined: Jul 2002 Posts: 17 | thanks I'm sure that I can get this accomplished sure appriciate the info
48 nick
#23129 07/09/2002 9:58 PM | Joined: Nov 2001 Posts: 11 Junior Member | | Junior Member Joined: Nov 2001 Posts: 11 | I must have missed the earlier posts on this conversion. I'd like to upgrade the ignition on our warmed up '61 235. I need to know what H.E.I. distributor to shop for to modify as you have detailed, and whether or not some have vacuum advance and others don't. I'd like to keep the vacuum advance. Am I looking for a later 250 H.E.I. before computer? What years do I need to look for. Seems like a much less expensive alternative than the $175.00 distributors I've seen advertised. TIA. | | |
#23130 07/10/2002 8:01 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Any 250, 194 or 292 HEI from 75 & on (pre-computer) will work. They're starting to get hard to find, though. If you have a good points distributor, you can get the Pertronix module for around $85 and drop it in. You can also buy rebuilds from the parts stores, price isn't bad if you have a core. Don't know how much the core is though.
Fred 52 3600 69 C-10
