7 members (eclector, 32Fordpuchoptop, Hotrod Lincoln, dt235sd, MickeyP, 2 invisible), 154 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#230982 04/04/2007 3:52 AM
Junior Member
Junior Member
I'm disassembling my 51 Chev and I can't get my steering wheel off. It looks like it's just on a splined shaft. Any ideas, is there a special tool? I've been tapping on the back side and cracked the wheel!! Thanks
#230983 04/04/2007 4:01 AM
Here is a previous discussion about the same topic. You can find some good info there. I did a search for the terms "steering wheel puller" and found several hits.
Welcome to Stovebolt!
#230984 04/04/2007 4:55 AM
#230985 04/04/2007 6:08 AM
A wheel puller makes it sooooo easy .
#230986 04/04/2007 7:16 AM
Wheel puller is of course the proper way but an old boy from Tennessee showed me a trick. Have someone pull up on the wheel. Place a brass hammer on the shaft and give it a good shot with another hammer. The steering wheel pops right off every time.
#230987 04/04/2007 2:05 PM
i got mine off by running the nut up to cover the threads and using my knees as leverage from below and striking the nut with a small hand sledge hammer. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#230988 04/04/2007 2:17 PM
Crusty Old Sarge
Crusty Old Sarge
Give it a shot of PB Blaster and let it set, use a puller if you can so you won't mess up the threads on the shaft. Put some tention on the puller and hit it with a brass dreft and hammer. Should come right loose.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
#230989 04/04/2007 2:32 PM
Ex Hall Monitor
Ex Hall Monitor
The way we did it "back in the day" was to set the seat to where you could push up on the back of the steering wheel with your knees, put one hammer on the shaft (after removing the nut of course), and whacking the top of the first hammer with another hammer. Worked great. Now that I have old knees I use my harmonic balancer puller with "J" bolts to hook over the arms of the steering wheel. That works great too. Just make sure the "J" bolts are as close to the hub as you can get them to minimize the strain on the steering wheel.
#230990 04/04/2007 6:06 PM
Tiny,
YOu prolly already know this but be careful hitting one hammer with another hammer. The heads are tempered and they can shattered when struck together, sending fragments out like shrapnel. One of the hammers, prefferably the one coming in contact with the threaded shaft, should be brass.
#230991 04/05/2007 9:48 AM
Junior Member
Junior Member
Thank you all......I got it off.
