| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 12 Junior Member | | Junior Member Joined: Mar 2007 Posts: 12 | I'm disassembling my 51 Chev and I can't get my steering wheel off. It looks like it's just on a splined shaft. Any ideas, is there a special tool? I've been tapping on the back side and cracked the wheel!! Thanks | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Here is a previous discussion about the same topic. You can find some good info there. I did a search for the terms "steering wheel puller" and found several hits. Welcome to Stovebolt! Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | A wheel puller makes it sooooo easy . | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Wheel puller is of course the proper way but an old boy from Tennessee showed me a trick. Have someone pull up on the wheel. Place a brass hammer on the shaft and give it a good shot with another hammer. The steering wheel pops right off every time. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i got mine off by running the nut up to cover the threads and using my knees as leverage from below and striking the nut with a small hand sledge hammer. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2007 Posts: 3,378 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,378 | Give it a shot of PB Blaster and let it set, use a puller if you can so you won't mess up the threads on the shaft. Put some tention on the puller and hit it with a brass dreft and hammer. Should come right loose.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The way we did it "back in the day" was to set the seat to where you could push up on the back of the steering wheel with your knees, put one hammer on the shaft (after removing the nut of course), and whacking the top of the first hammer with another hammer. Worked great. Now that I have old knees I use my harmonic balancer puller with "J" bolts to hook over the arms of the steering wheel. That works great too. Just make sure the "J" bolts are as close to the hub as you can get them to minimize the strain on the steering wheel.
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Tiny, YOu prolly already know this but be careful hitting one hammer with another hammer. The heads are tempered and they can shattered when struck together, sending fragments out like shrapnel. One of the hammers, prefferably the one coming in contact with the threaded shaft, should be brass. | | | | | Joined: Mar 2007 Posts: 12 Junior Member | | Junior Member Joined: Mar 2007 Posts: 12 | Thank you all......I got it off. | | |
