6 members (TexasJim50, Stovebolt48, 32Fordpuchoptop, lumbersawyer, JW51, 1 invisible), 56 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
#230942 04/03/2007 11:34 PM
I want to take the "moons" off the wheels of a 15" wheel on my 53 Bolt. They fit over the nubs on the wheels, no clips--just nubs. They are brand new and need decals attached. I am wondering about the best way to pry them off so that I don't scrape the paint, and, even more important, how to put them back on without denting them.
Any help would be welcome!!!
Ex Hall Monitor
Ex Hall Monitor
I'm having a similar problem with my 38 coupe. I've already damaged the powercoat removing them once. I have an idea I'm going to try if I can find the right material. I'll follow this thread and post here if it works.
I took an old, cheap screwdriver, heated it up and put a 90 degree bend in it. Then use a pad under the pry point. Pops 'em right off!
I got some nylon pry bars from Summit Racing, around $15. Have taken the hubcaps off the rims once or twice and no damage.
works pretty good.
1936 GMC T-14 1/2-Ton Pickup
Dunfire...
How did you put them back? Did you use a rubber hammer? I am concerned about denting them somehow.
BTW, I just ordered the nylon pry bars; thanks for the suggestion!!!
If they are plated, try using a brake adjustment tool.
Shmoo, I just get them started on the clips on the wheel and take the palm of my hand and give a firm shove. My hubcaps are repo's that I got from the Filling Station.
Ex Hall Monitor
Ex Hall Monitor
Nylon pry bar eh? I just happen to have a Summit Racing catalog. Me thinks I'll be taking a look. Thanks for the tip.
Yes how do you put them back on with out denting them or is that aforegone result......Peter
just push them on firm, don't force anything, or hit them, the should pop on
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
thats easier said then done lol. Peter
