4 members (Tim Canfield, Bill Hanlon, Hotrod Lincoln, 55shaker), 108 guests, and 4 robots.
Topics128,195
Posts1,057,380
Members48,469
#230737 04/01/2007 3:06 AM
i have a 52 3/4 ton 2wd flatbed. i ordered the parts autozone said would fit, but the new pins were about 3/8 longer and skinnier(.040!!) than mine. has anyone else with a 3/4 ton had the same problem? i ordered the other two sets that are listed for the truck, so ill see in a few days if they fit. also, i have no id tags on the truck, how can i tell if its a 3600 or 3700? any tips would be appreciated. thanks
#230738 04/01/2007 3:36 AM
wheel base would be the easiset way, or check the door id plate to see if its 3600 or a 3800
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#230739 04/01/2007 3:39 AM
jamesgs4,
I think that was a smart move on your part. Order every kit listed, keep the correct one and return the others.
Stuart
#230740 04/01/2007 3:39 AM
Pickups were the 3600. The 3700 was the forward cotrol (step van) model. Either way, the kingpins should be the same as they are both 3/4 ton nominal rating. I'd say they got the wrong parts, may not even be for a Chevy.
Bill Burmeister
#230741 04/01/2007 3:40 AM
I wouldn't buy a cotter pin from auto zone, deal with Napa etc. Also check vendors linked to this site.
1946 1/2-Ton Chevy
#230742 04/02/2007 2:12 AM
I got my king pins for my 53 3600 from Chevy Duty. Other than the typical machining for the bushing fit there were no problems.
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
#230743 04/02/2007 6:44 AM
i just got the correct set from napa, and i found that i have to have the spindles machined for the bushings. i think i will go to a mustang II front end kit if i ever have to do anything with this front end again. easy to find parts and disc brakes sound really good about now.
#230744 04/03/2007 1:14 AM
I hear ya...King pins are a pain. I am trying to keep mine stock but a mustang II would be the way to go if you decide to upgrade.
1953 3/4-Ton Chevy
More pix
RB53
