2 members (39Master85, 2Wheels),
105
Mod | | | Forums66 Topics128,196 Posts1,057,396 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 22 New Guy | | New Guy Joined: Mar 2007 Posts: 22 | i have a 52 3/4 ton 2wd flatbed. i ordered the parts autozone said would fit, but the new pins were about 3/8 longer and skinnier(.040!!) than mine. has anyone else with a 3/4 ton had the same problem? i ordered the other two sets that are listed for the truck, so ill see in a few days if they fit. also, i have no id tags on the truck, how can i tell if its a 3600 or 3700? any tips would be appreciated. thanks | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | wheel base would be the easiset way, or check the door id plate to see if its 3600 or a 3800 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | jamesgs4,
I think that was a smart move on your part. Order every kit listed, keep the correct one and return the others.
Stuart | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Pickups were the 3600. The 3700 was the forward cotrol (step van) model. Either way, the kingpins should be the same as they are both 3/4 ton nominal rating. I'd say they got the wrong parts, may not even be for a Chevy.
Bill Burmeister | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I wouldn't buy a cotter pin from auto zone, deal with Napa etc. Also check vendors linked to this site. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I got my king pins for my 53 3600 from Chevy Duty. Other than the typical machining for the bushing fit there were no problems. | | | | | Joined: Mar 2007 Posts: 22 New Guy | | New Guy Joined: Mar 2007 Posts: 22 | i just got the correct set from napa, and i found that i have to have the spindles machined for the bushings. i think i will go to a mustang II front end kit if i ever have to do anything with this front end again. easy to find parts and disc brakes sound really good about now. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I hear ya...King pins are a pain. I am trying to keep mine stock but a mustang II would be the way to go if you decide to upgrade. | | |
