1 members (Steelonsteel), 44 guests, and 3 robots.
Topics128,090
Posts1,056,024
Members48,432
#230561 03/29/2007 11:36 PM
Hi, I"m Curtis and I am trying to get all the info I can on the 1962 Chevy suburban before I buy it .One question I had was about the rear floor is it made of wood or metal ? What I saw was wood but didn"to know if this vehicle was modified or not .Does the seats fold down in the rear ?How many were made this year? How do I find out the original spec"s and color of it? thanks Curtis
#230562 03/30/2007 1:20 PM
Wood(plywood)covered w/rubber mat, seats don't fold, there is a trim tag on the kick panel showing the color code. Welcome to the Bolt,,Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#230563 03/30/2007 1:41 PM
i believe it should have hab a wooden floor
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#230564 03/30/2007 6:42 PM
we had a 63 suburban. the wood floor starts at the rear doors and goes all the way up to the second row of seats. when you are sitting upon the second row your feet will be on steel flooring. the joint between the two substrates is under that row of seating.
as far as finding color names and codes, take the code as 64fleetside states and look it up in a book called "chevrolet pick up red book". this book has all the coding break downs from 1946 to 1972. author is peter c. sesslor
cheers, mike
1947 Studebaker M15 on 76 GMC one ton dually chassis with 454 4 spd
1953 Chevrolet 1/2 ton p/u
1957 Oldsmobile 88 2dr hardtop
1959 B130 International one ton dually
#230565 03/31/2007 4:56 AM
The original middle and rear seat had carriage head bolts mounting upside down on the bottom feet of the seat frames. The heads went into key-hole shaped slots in the floor. A wing nut on the threaded part of the bolt was used to tighten it up.
I've got a '62 and use it as my daily driver. It's a rough old primative truck, but I LOVE it.
The front suspension is a torsion bar type front end. Only used on 1960-'62 trucks. It's expensive to rebuild these using stock replacement parts. If you're handy with tools and somewhat mechanically inclined, you can convert it to a later coil spring type front end without too much difficulty.
If you plan on upgrading the brakes to front discs, it's expensive on these trucks because the clutch uses hydraulic clutch linkage, with a fluid reservoir. That reservoir needs to be taken into account when upgrading the brake master cylinder. In '63 they went to mechanical clutch linkage, doing away with the reservoir. From what I understand, it's a pretty common modification to convert to mechanical linkage. Brake kits incorporating the hydraulic clutch are availalbe, but more expensive.
The '60-'63 wrap-around windshields are 2-to-3 times more expensive than the flat '64-'66 windshields ('60-'63 is usually about $350-$450, plus shipping).
Finally, the middle and rear seats for these trucks are very hard to come by. So are the original 60/40 split bench fronts for that matter.
So are the window latches for the sliding side windows.
However, in the year I've had my truck, I've bought a full-width middle row seat, latches for the two sliding side rear windows (some trucks had all four side windows that opened), a front 60/40 bench that needs to be completely rebuild, and the hard-to-come by original 6-bolt steel wheels. I've also found two rust-free/dent-free doors, a solid front fender, two rust-free innner fenders, and a complete tail and lift gate assembly to replace my barn doors. And I've done it on a very, very tight budget--around $500 for all of those pieces, sourced from many different places. So it can be done.
If I had it to do over again, I'd probably look for a '63, only because of the torsion bar front end. However, I really like the way the T-bar rides, so I'll bite the bullet and rebuild it. Should only have to rebuild it twice in my life time.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
