0 members (),
81
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Do any of you have a photo of an original plunger starter linkage on a 55-59 truck?
I am planning on running this on my truck. I have a 48, but with a 56 235 in it. I have a 55-59 bellhousing and thought this linkage bolted to it, but I can't for the life of me figure it out. There is no place for it to bolt.
Is the linkage the same 47-59, that is how I bought the set up I have.
Any photos or knowledge would be greatly appreciated.
Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I have 2 bellhousing, one from a 1959, 261 engine. The other one in from a 1953, 235 engine. The bell housings look exactly the same. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Hmm, how about this linkage, where the heck does it mount? I looked at the cross member, the floor, is there something I am missing?
Brian
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Thanks Stuart, but I can't make out where the darn thing bolts on to. It looks like the top of the bell housing, but I didn't see where this would be on mine. I have the bell housing stuck under a shelf in the dark, I was just on my hands and knees looking at it. Maybe I should pull the fool thing out and take a better look? Here is what I have. I can't figure out where the two bolts on each side bold. Brian picture
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Something in the picture doesn't seem right. The starter should be on the right side of the engine and the stomper is slightly toward the drivers side from it. Something looks backwards in the pix!
Stuart | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I'm going to go out on a limb on this one...I don't think this is for a Stovebolt. As was mentioned in another thread today, slap me if I'm wrong. Stuart | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | The foot stomp part is in backwards is all. The two bolts on each side bolt to the top of the bellhousing. Hope this helps.  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Martins is the correct one, just has the pedal part in from the wrong face as shipwright sez, should be pointing at the floor in that pic Martin, not great pics cuz of the location, but here's the drivers side , and the passenger side - note there's 2 small pads that should have the bolt holes Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | HEY, that's no fair...pix trix! Should I consider myself 'slapped'! :p
Stuart | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There is a flat spot on top of each side of the bellhousing with 2 threaded holes. The "straps" bolt to that with the bolts coming down through the top. I've seen some bellhousings that don't have holes drilled there- like the one that came with my '62 261 with hydraulic clutch. If you don't have the right housing there won't be a spot to bolt the pivot points.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | | | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Brian, by the way, the linkage set-up in your picture is the same as what I have for my '53. The bellhousing photo I posted shows the top where the linkage bolts on. This bellhousing was originally on a '55 235 and I used the same one on the '61 235 block I now have installed in the truck. The foot pedal starter comes unscrewed from the linkage and goes through the floorboard from inside the cab, then screws back onto the linkage. The linkage lies on top of the bellhousing. The photos don't show it real well, but I think you can see enough to figure it out. Rick | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Thank you so much guys, Rick, you went above and beyond the call of duty guy, THANKS.
I'll be damned if the bell housing I got was advertised as 55-59 but it doesn't have those bosses for the linkage to bolt to!!! CRAP.
I think the guy will work with me, I also bought the linkage from him. CRAP!
Thanks to all, Brian
| | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Glad to help, Brian, but sorry to hear it isn't working out with the bellhousing. Hope the guy makes it right with you. Good luck. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Brian,i see you already have your answer.I'm posting a picture of a 1954 bellhousing from a 1954 261 engine. 1954 bellhousing 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Brian - maybe you got a V8 bellhouse, they don't have the foor start, any that fit 216, 235, 261 should have provision for the foot start
Bill | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | No, I'll tell you what I have is a car bell housing. They used the electric start from 53 on from what I understand (and remember). My bell housing looks exactly like the one Tim posted (thanks time) but without the bosses for the linkage.
The guy I bought it from says he'll see if he has the right one for me and we'll swap.
Now, I wonder if the armature I got is going to work. When I started this project I hadn't even thought of using the plunger starter. All I knew is I wanted the 55-59 bell housing to put my 56 235 in my 48 truck. All I need is the 55-59 car starter and there it is. So I bought a starter and what was advertised as an NOS 57-62 armature. I bought it thinking it was what I needed for the starter. But now I am not so sure. And I wonder if that wasn't a waste. NOS parts are never too much of a waste as I can always sell it. But I'll have to properly identify it.
Brian
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Make sure you get the right bellhousing you need.The rear mounts are different on certain years.On my 1951 they bolt to the side of the bellhousing.The 1954 bellhousing is beveled where the mounts bolt up.Do a search on bellhousings.I don't know how it will effect your "1948" install using the 55-59 bellhousing.
I'm sure someone will step in anytime and explain. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Thanks for all your help, I got the right housing, the right linkage and I am on my way, THANKS for setting me straight.
I have a new quest, but will start a new thread.
Brian
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You also need to make sure you have the right bell housing for your transmission. The 3 speed has a pin sticking out on the top drivers side for the swing mechanism for the shifter.
I made the mistake of buying one without this pin. I got mad not only because I could not use it but because I carried it around while at a swap meet. Now I take a wagon. Anyway, I think the ones without this pin are for use with a 4 speed transmission. Or maybe an automatic.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Interesting post, turns out the bell housing off my 270 has the holes drilled & tapped for this part. Would make an interesting conversion anyway.  1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
