| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | I seem to remember reading on the forum some time back that weak hood springs were the cause of the hood staying a little too high at the rear. I just got around to attempting to adjust mine on my 1960 apache stepside. I adjusted the rear bumpers on the hood which ride on a little platform on the cab. Now the passenger side sits down correctly, but the drivers side rides up about 1/8 inch. I can push it down by hand and it will almost stay, but seems to be spring loaded to pop back up to the original 1/8 inch too high. The adjustment of the hood hings to cab is at the lowest possible setting. It's hard to tell by looking, but would a new and stronger spring fix this problem? The hood barely stays up by itself since I lubed the hinges. meansam | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | if your hood barely stays up, i would replace them, and that might help your other problems too, you may have a weak and slightly tweaked hinge, i had to replace the one on my 63, it had the same problem, i put another used set on and i was good to go 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | The rear of the hood on my 70 wouldn't close down. Bought new hinges and springs and it is all better now. | | |
