0 members (), 155 guests, and 3 robots.
Topics128,167
Posts1,057,018
Members48,458
#230250 03/25/2007 10:03 PM
I seem to remember reading on the forum some time back that weak hood springs were the cause of the hood staying a little too high at the rear. I just got around to attempting to adjust mine on my 1960 apache stepside. I adjusted the rear bumpers on the hood which ride on a little platform on the cab. Now the passenger side sits down correctly, but the drivers side rides up about 1/8 inch. I can push it down by hand and it will almost stay, but seems to be spring loaded to pop back up to the original 1/8 inch too high. The adjustment of the hood hings to cab is at the lowest possible setting.
It's hard to tell by looking, but would a new and stronger spring fix this problem? The hood barely stays up by itself since I lubed the hinges.
meansam
#230251 03/25/2007 10:10 PM
if your hood barely stays up, i would replace them, and that might help your other problems too, you may have a weak and slightly tweaked hinge, i had to replace the one on my 63, it had the same problem, i put another used set on and i was good to go
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#230252 03/26/2007 2:57 AM
The rear of the hood on my 70 wouldn't close down. Bought new hinges and springs and it is all better now.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
