| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I just had a quick question regarding the removal of the A-Arm shafts. Am I missing something or is it a matter of brute force to remove those large nuts on each end? I guess they've been on since '66 so not easy. Are there any tricks I need to know? Gary
GS
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | First I would try hosing them down with WD-40 then put a wrench to them, try tapping the end of the wrench instead of just trying to turn it because, like an impact, that jerking movement will bust it loose. If that doesnt work you could heat it up then try the wrench.
58' 3200 235 3-speed/OD
| | | | | Joined: Oct 2006 Posts: 14 Junior Member | | Junior Member Joined: Oct 2006 Posts: 14 | PB Blaster is great at helping to break the nut lose. It seemed to work better that WD-40 on my 68 c-10. I went through about 4 cans of the stuff. Just spray and walk away...have a Coca-Cola...and come back ready to teardown!
And a 3 pound hammer helps on that tapping the end of the wrench. LOL
God is good all the time and All the time God is good.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'd suggest forgoing the wrench and going to an impact, you'll get it done alot faster. Also, and I may be mistaken, I think that the nuts might be left hand thread on one side. don't remember which way it is though.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I had a 1966 c20,I had to use an impact on them. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ve always used an air impact on them. They are all right hand threads. Sometimes if the hole gets wallerd out you need to weld it in to keep it from backing out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
