5 members (Charles in CA, mick53, Gray_Ghost, BC59, klhansen), 168 guests, and 1 robot.
Topics128,113
Posts1,056,277
Members48,439
Junior Member
Junior Member
Hi all.
I just got my login info approved and I have a question. I'm looking for the piece of trim that goes across the back of the cab of an early '60's Custom. I already have the two side pieces but I haven't been able to locate a back piece.
I have searched the board but I haven't had any luck.
Any help will be appreciated.
welcome to the shop tank - I don't think those are reproduced, so yer lookin for used - and I think the 60-63, if that's what you need, is different than the 64-66
yer best bet is make a post in the parts wanted part of the swap meet, eventually something will show up
Junior Member
Junior Member
Hi Bill,
Thanks for the reply. Yes, used for a 60-63 is what I am looking for. I know the side pieces are different 60-63 and 64-66 but did they even use the piece that goes under the back glass after 63? I don't think I have ever seen a 64 or newer with it, but then again I haven't really looked.
I knew that this area gets more traffic but I'll go post in the parts wanted area also.
Thanks again,
Tank
Hey Tank, I am just north of you near Cabot, welcome to the Bolt. That trim was only used in 60 some say & only on the Custom cab, & I have never seen it on a 64-66 so that may be true. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Never seen it on a 64-66. I am up here in Pocahontas.
Junior Member
Junior Member
Hi 64fleetside,
Thanks for the welcome and the information. I'll be in Cabot later this week to pick up my tractor at Cabot Outdoors. I had a little hydraulic problem that they had to fix.
From looking at the assembly manual I have, they only show that piece in 60. Everything after that just shows the side pieces. I may be looking for something that is going to be very hard to find.
Wow, small world-my lawnmower, weedeater & chainsaw all came from Cabot Outdoors. Good people. Yes I believe that trim is tough to find, you can try the usual suspects-Tom Myers in Miami,OK;; RJ here in the swap meet area. Brian
Ok, this should have been in the swap meet but it turned into a discussion of what years a certain trim piece was used so I left it here. Now it has morphed into something else so I'm locking it.
