1 members (KEVINSKI),
160
Mod | | | Forums66 Topics128,108 Posts1,056,228 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 3 Junior Member | | Junior Member Joined: Mar 2007 Posts: 3 | Hi all.
I just got my login info approved and I have a question. I'm looking for the piece of trim that goes across the back of the cab of an early '60's Custom. I already have the two side pieces but I haven't been able to locate a back piece.
I have searched the board but I haven't had any luck.
Any help will be appreciated. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the shop tank - I don't think those are reproduced, so yer lookin for used - and I think the 60-63, if that's what you need, is different than the 64-66
yer best bet is make a post in the parts wanted part of the swap meet, eventually something will show up
Bill | | | | | Joined: Mar 2007 Posts: 3 Junior Member | | Junior Member Joined: Mar 2007 Posts: 3 | Hi Bill,
Thanks for the reply. Yes, used for a 60-63 is what I am looking for. I know the side pieces are different 60-63 and 64-66 but did they even use the piece that goes under the back glass after 63? I don't think I have ever seen a 64 or newer with it, but then again I haven't really looked.
I knew that this area gets more traffic but I'll go post in the parts wanted area also.
Thanks again,
Tank | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Hey Tank, I am just north of you near Cabot, welcome to the Bolt. That trim was only used in 60 some say & only on the Custom cab, & I have never seen it on a 64-66 so that may be true. Brian | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | Never seen it on a 64-66. I am up here in Pocahontas. | | | | | Joined: Mar 2007 Posts: 3 Junior Member | | Junior Member Joined: Mar 2007 Posts: 3 | Hi 64fleetside,
Thanks for the welcome and the information. I'll be in Cabot later this week to pick up my tractor at Cabot Outdoors. I had a little hydraulic problem that they had to fix.
From looking at the assembly manual I have, they only show that piece in 60. Everything after that just shows the side pieces. I may be looking for something that is going to be very hard to find. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Wow, small world-my lawnmower, weedeater & chainsaw all came from Cabot Outdoors. Good people. Yes I believe that trim is tough to find, you can try the usual suspects-Tom Myers in Miami,OK;; RJ here in the swap meet area. Brian | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Ok, this should have been in the swap meet but it turned into a discussion of what years a certain trim piece was used so I left it here. Now it has morphed into something else so I'm locking it. | | |
