9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible),
125
0
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22973 03/18/2004 12:33 AM | Joined: Feb 2004 Posts: 18 Junior Member | | Junior Member Joined: Feb 2004 Posts: 18 | I have a 3800 with 216 egine, all original. I see the bypass oil filter stays full of oil.
That must mean that there is a check valve in the return line to keep the oil from draining back?
Or does it mean the return line is really blocked and no oil is flowing through the filter?
Which is it, or what else keeps the oil in the filter can when engine is not running????? | | |
#22974 03/18/2004 4:23 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | DGK, There is no check valve in the canister.The center post in the canister is a double sleeve. The oil is pumped up the inner sleeve which is shoter than the outer sleeve. Once it reaches the top of the inner sleeve it drains down into the canister. The inner is not much shorter than the outer. This is why the canister stays full. It only back flows a 1/2 of an inch or so. Also, these are absorbtion filters. Not forced thru filters. The drain hole in the outer post is below the lower level(bottom side) of the filter. Glenn, | | |
