| | | Forums66 Topics128,140 Posts1,056,776 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | I saw this article somewhere, I thought it was Patricks site but I can't find the darn thing, any suggestions?
Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | it will work you just have to change water pump to short shaft 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | That is my thing, what is a "short shaft"? It is the shortened ones you have modified? Or are you talking using the early waterpump with an adapter?
Brian
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brian, Chevytrucks.org has an article by Patrick on swapping a later 235 for a 216. Maybe this is what you are looking for. There have been a lot of postings about the options for putting a short shaft water pump in this kind of swap. Some vendors sell a short shaft pump for the newer engines; or, an adapter plate allows the older water pump to work on the newer engine. The advantages of the adapter plate are (1) the fan is in the correct location, and (2) it looks a little more original. short-shaft pump adapter plate Tim | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Thank you so much Tim, I thought I had seen it there but couldn't find it yesterday. I went to the wrecking yard yesterday and found a 51 Flat bed to rob some parts off of. It had a later 235 and looking at the hacked up rad support and latch panel I was reminded that my truck looked like that when I bought it back in 73. Though it was a lot cleaner done, it was wrong. I am going back in time  and putting a 235 back in and want to do it right. Again, thanks a lot! Brian
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Brian, Having done this swap with my 261 in my '50 I would recommend going with the adaptor plate and a 216 water pump. I shortened the stock pump myself and found a junkyard pulley that fits right. While it fits behind the radiator, I can't run a mechanical fan, it just doesn't fit- it hits the bottom radiator hose. I am running an electric fan mounted on the front of the radiator. It works but I don't like the sound it makes.
A 216 pump would mount higher and solve all those problems.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Thanks, I'll be planning that. Wanta buy a nice unused rebuilt 55-59 pump? Brian
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Ok, so let me get his clear, that photo is of a 216 pump with the adapter?
Brian
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | No, that's what you get without the adapter. It will threaten to overheat in traffic, and narrowly misses the balancer and lower rad hose. I do have enough room to slip in a new belt though. The adapter will lift the fan up to center it on the rad. Don't have a picture of the adapter in place but there's one of a 216 pump in that album so you can see the difference.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Originally posted by MARTINSR: Thanks, I'll be planning that. Wanta buy a nice unused rebuilt 55-59 pump?
Brian Nope- I'm pulling the 261 and putting in a GMC 302. I'll have to slide the radiator forward a bit but at least the water pump is in the right spot on the block. I've got a few 235 pump cores I never took back to Napa, I wonder what they are worth? I used them as experiments in modifying my 261 pump.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | The thing is my truck is sectioned so the rad is going to have to be a little shorter, ala 1953ish passenger car (I am making a 53 Vette motor with the Vette three side draft carbs) So I am wondering if the 55-59 pump may be the way to go and then just deal with a way to get the fan some clearance.
Brian
