0 members (), 122 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#229684 03/18/2007 11:09 PM
I just used siver solder to fix the tank on my 48 radiator,I'll never go back to regular solder.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
#229685 03/19/2007 12:19 AM
tntrucknut,
Interesting. I use silver solder quite a bit making brass parts for banjo makers. Conventional soft solder melts below 500&deg Fahrenheit while most silver solders melt above 1000&deg. I am surprised you didn't melt any of the adjacent soft solder when applying the silver solder.
It seems like it would be quite difficult to repair an area where both types of material were present.
Stuart
#229686 03/19/2007 12:20 AM
i've done that too. i hopes it wouldn't run out when it got hot. eek the sticks are so much better than the rolls as well. mine held fine i actually had to patch in a piece of brass, a bracket rubbed a big hole in the bottom. hr
#229687 03/19/2007 12:24 AM
Doing it right is the only way to go, but If you are in need of a temporary fix I have used pepper before with excellent results
#229688 03/19/2007 12:29 AM
i used silver solder on my 49 radiator 3 years ago and have had no problems
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#229689 03/19/2007 2:03 AM
Where can one get siver solder ,parts store ? •••• can u solder that with a solder gun are need need more heat ? ..
Never take a sleeping pill and a laxative at the time.[/i]
1955 Chevy 3100
More pix on Photobucket
#229690 03/19/2007 4:10 AM
A soldering iron will not get hot enough for silver solder. A oxy-acetylene torch or maybe a MAPP gas torch must be used. Silver solder takes a specific flux which must be purchased too...unless you find a flux covered rod.
I guess the part of this thread I am missing is why use silver solder at all. The benefit of the silver solder is its high strength. Most radiator applications do fine with the strength provided by regular soft solder. It's much more about sealing two pieces for a water tight pressure joint than it is about brute strength.
Stuart
#229691 03/20/2007 2:03 AM
The top tank was cracked about two inchs,if I had used regular solder I would have had to use a patch.And you don't have to use flux with silver solder,just make sure its sanded good.
The flux covered rods are usually brass.
Floyd
_____________
Floyd
1948 Chevy 2-Ton
