2 members (rfs56trk, Guitplayer), 78 guests, and 0 robots.
Topics128,108
Posts1,056,566
Members48,448
After reading through 67 posts doing a search for tranny here is my question.
I have a 53 1/2 ton with a 54 235, 3-speed on tree and torque tube drive.
I want to put in a mid 80's 4WD K-5 Blazer rearend (6-lug), keep the 235 and the 3 on the tree.
What tranny and years should I shop for?
This truck is for cruzin, not hauling.
Mark
1946 1/2 ton - 1962 "261"
1953 1/2 ton 5-window - "235"
1955 1/2 ton - 55 "265" Corvette motor
1959 1/2 ton Fleetside - "283"
Any '55-62 tranny will work, that is when they went to the open driveline. You can also switch to an SM420 if you want four speeds.
Paint & Body Shop moderator
Junior Member
Junior Member
Mark,
I made this swap just recently. My advise is to keep the original rear end and change the ring & pinion. In my swap I used a 79 camaro rear with a full syncro 3 speed saginaw. The 3 on the tree linkage was a real BEAR. I took me a long time to fabricate the linkage using some parts from a MR. Gasket 3-speed stick shift linkage. It works but the shifter sometimes sticks. And the throw is shorter for reverse & first than second and third.
If I had to do it again I would just swap the ring & pinion. I could send you some pictures of the fabricated linkage. It might help you to make up your mind about which way you want to go.
The truth will set all men free.
If you can swap side cover, levers, etc. from your old trans. to the donor, it should be much more painless. Am currently doing that with my 56, swapping in a mid-60's 3-spd OD behind a 261 with a Chevelle 12 bolt posi.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
