3 members (Wheelie, tclederman, Woodcmiami), 113 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#229523 03/16/2007 11:34 PM
I'm wrestling with how to shorten the steering column and thinking about using a reversed corvari box mounted where the original box goes, using the original column and a borgesen joint.
Does anyone have any experience with the reversed corvair boxes, like how many turns lock-to-lock are they?
I would love to go with a power steering set up but I just havn't been able to figure out a good way to mount the P/S pump since I've got a/c on my 261.
Sorry, frown
It seems that there are no others, so now it is up to you to figure it out and take some picture so we can have it as a Techtip smile Around here, when you can make it up, you can build it, just use lots of twine and barbwire to hold it together grin I know, us farmers keep everything going that way.
Good luck and if... keep us posted, not all members here have the knowledge or vision to make changes like that.
Quote
How about a generator power steering pump combo with the pump behind the generator?
Steve
'49 3800
'52 3600
'57 3100
I converted to 12v and am now using an alternator. Unfortunately, I havn't seen any alternator-p/s pump combos. The closest I've seen is the Izusu alternator-vacuum pump combo for the diesel engines.
I haven't seen one but there have been several posts about a remote electric/hydraulic pump in some foreign cars and also about the electric power steering (all in the column) I think may be in a Saturn. A click on "search" on this might bring them up.
Evan
