2 members (Gdads51, WICruiser),
84
Mod | | | Forums66 Topics128,268 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I hate to admit defeat, but I can't get the leaf spring bolts out of the shackle/hanger.Would anyone like to tell me how they come out. Its on a 57 3200 rear leaf spring fr & rear threaded bolts. Should I buy new ones? I have a photo in Photobucket. Thanks for any advice. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i'm not sure but it think you tap the out, new ones souldn't be that much, i'd put new ones in it 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Soak all with PB Blaster or Kroil then smack them... If still doesn't come apart, heat them with rosebud on yer torch and smack 'em again...
As a last resort I've cut the shackles (got new ones) and used a rosebud and press to get the bolts out of the springs..
Good luck........
Geoff
49 Chev 4400 52 GMC 350 55 Chev 3800 1st series 37 RD4 Cat 50 JD420C w/JD90 Loader
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You're talking about the shackle end, correct? The factory pins are an interference fit into the side plates. Once you remove the center bolt, you'll have to tap the side plates off of the pins. They should come off wiht just a little bit of force. I wouls strongly suggest thet you get a new shackle/pivot pit kit, they're not too expensive. Not too hard to put in either. You'll have to press out the old bushings, I made a press for this out of a 1/2" carriage bolt and some washers. Use the bolt wiht a socket the size of the bushing to press it out, you'll need to use a larger socket on the opposit side to act as a reciever tube as well. Then simply use the bolt with a stack of fender washers on the bushing and on the opposite side of the spring. Hold the square under the head of the bolt with a wrench and turn the nut to press the new pin in. The new pins use self locking nuts in addition to the taper to hold the side plates on, but the center bolt should be installed, too, as a precaution. One word of advice-If you do replace the front pivot bushing/pin, most kits I've seen come with a straight grease fitting. You cannot get onto this fitting once the bed is installed. I replaced mine wiht 90 degree fittings so that they can be greased.
Bill Burmeister | | |
