2 members (Chris's 46 / 515, 2-Ton), 86 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
#229258 03/13/2007 5:01 AM
Former Workshop Owner
I picked up a copy of his 1954 (reprint) Chevy Inline 6 Speed Tip book at a swap meet yesterday. I have only skimmed through a couple chapters, but it looks like it will be some interesting reading.
Has anyone else read it, and are there any more similar books that anyone can recommend?
I have acquired a couple 235's and one 216 that I am tempted to experiment with.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
The 235s are a much better place to start... if they are full pressure 235s. The 216 requires a lot more work on the bottom end and then has the smaller displacement. If you want to get real serious, you would build a 261 chevy, or a 270 or 302 gmc. There is no substitute for displacement.
P.S. I have the little yellow book... California Bill Fisher's GMC Speed Manual. It is good reading, but is a little out of date. He talks about knurling pistons, a practice that simply isn't done today, and grinding the crank an extra 2 thousandths fore more oil flow to the bearings, which again isn't common practice.
Another one is How to Hop up Chevy and GMC engines. Link
Steve
'49 3800
'52 3600
'57 3100
ive got copys of both of them and they are great. especially the prices they quote. wink
Thanks, I forgot to count the 235 that is in the truck. So I have 4 total that I can take apart, 2 full pressure 235s, 1 each 235 and 216 low pressure (dippers).
I have some steel parts tubs that I can use to help keep the parts separated. I will probably take apart 2 and pick the one in the best shape to rebuild.
Never messed with an inline before, I always replaced them with V8's. This is going to be a learning experience.
Thanks Again
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
I've always wanted to take two heads from an appropriately sized and spaced v-8, lop off one cylinder and then weld the two 3-cylinder heads together and mount them on a 261 with the intake on one side and exhaust on the other.
I read somewhere that someone did that and it worked well, but I haven't been able to find the article since I first saw it.
