0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | ***EDITED 3/16***
After taking off the fall and most of the winter I'm finally back to work on my 51' 1/2 ton!
I have been trying to figure out how to create some clearance between my belly and the steering wheel and came up with the following options:
1.New column and steering box. I could even keep the original column and just cut it and use a borgensen joint to connect it to a new box. The box would have to be manual since there isn't anywhere to mount a p/s pump on my 261 now that I've got a/c. Problem is, I don't know of any boxes that could mount in the original location and I don't want to cut the fenders to use a saginaw box. Does anyone know if a reveresed corvair box would work?
2.Get rid of the springs in the back of the seat and use a piece of plywood instead.
3.Cut a couple of inches out of the original column, tig or mig weld it back together, sleeve it and then take an equal amount out of the column housing aka Mast Jacket.
4.Southbeach diet and don't drive til I'm back down to my fighting weight.
I'm leaning towards option 3: cutting, welding and sleeving the original column 'cause it'll keep the original look and feel and I won't have to mess with the original seat.
Any suggestions or tips?
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Seems like #3 would be about the easiest. However, if you wanted to upgrade to a power steering box, kits are sold to adapt a '69 to '87 or so 2wd power box to your truck. If you went that route you could adapt your original column to the new box and would have to cut it anyway, so you could shorten it as well and keep the stock column. Or.....maybe this could be incentive to increase your belly to steering wheel clearance without shortening the column!  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, I would definitely go with #4 - not only much cheaper, considering the savings at the grocer, but healthier to boot Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | What did I miss....I don't see #4! Is this 'north of the 49th' humor. Stuart | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Naw man, even a Cave Man can get it! :rolleyes:
~Jim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Originally posted by Ghostrider: .... Or.....maybe this could be incentive to increase your belly to steering wheel clearance without shortening the column! #4, which everyone north of the 40th is workin on this time of year Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Sorry, missed it completely. Guess I was out with my friends from Geico in search of fire! Stuart | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well if number 4 is called for, I won't argue against it. But don't ask me to live that approach!
I'm still thinking on number 3. Instead of cutting and welding the actual steering column can you simply cut a couple inches off the steering wheel end, and modify the end to take the wheel?
I don't know if its possible, and don't have one far enough apart to check that option, but I'd sure want to look into it before cutting and welding the column.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I think the spline arrangement on the steering wheel end of the shaft would take a very special operation to replicate.
Sectioning the shaft and housing should be easy and safe if prepared properly and done by a skilled welder..especially if the shaft could be sleeved too.
Stuart | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have the same problem with my 72.The easiest fix is a good weight loss diet. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Well, I'm going with #2 (sorta). Here was my problem - the original seat put me too close to the steering wheel, and the foot pedals. SO, I pulled the seat out and did the following:
1. Compressed each coil in the back of the seat about 2-3", then tied it down with wire (sounds like a lot of work, but it only took an hour or so) The seat still "gives" a little.
2. Took a 1 1/2" section out of the seat riser (the metal frame attached to the floor) and a similar amount out of the rear seat mount tower.
3. Cut the "hooks" on the top of the seat back off so that the back rests against the back of the cab (I put some weatherstripping on the seat frame to keep it from rattling)
Now, I sit farther back, lower in the cab, and can stretch my lets out and it doesn't feel like my head is right next to the roof of the cab. The seat is much more comfortable, and the best thing is, it looks stock. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | I've seen too many accidents on the racetrack with cut/welded steering shafts to ever try that, plus the bushings in the mast jacket won't let a sleeved shaft pass through them unless the sleeve is turned down to original diameter. The steering shaft is hollow in most cases to let the horn wire pass through it, so you're dealing with a limited thickness of metal to begin with. How about adapting a tilt wheel assembly and a more modern steering gear, with a flex joint below the column? Jerry
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Personally, I am doing some pushaways. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by atomarc: I think the spline arrangement on the steering wheel end of the shaft would take a [b] very special operation to replicate.[/b] That may be, but my little brother has set up a light weight machine shop at home and I'm amazed at some of the things he now does. Having a mill, lathe and other toys creates more options than I imagined, and some of those options might be far safer than a welded steering column. Just my two cents...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i just slide the seat all the way back, and suck it in a little  - what about changing the steering wheel, a car wheel? aren't they a little smaller anyway?, or one of the nice looking wood-grain wheels, lmc carries them. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Advance Design steering shafts are solid steel, not hollow...about 3/4" or 13/16" dia. The horn wire is run inside the mast jacket. Sectioning/shortening steering shafts is pretty common place in the street rod world, and as Stuart stated, easy and safe if prepared properly and done by a skilled welder. Borgeson Universal Joint Co. sells weld on couplers/adapters for smooth shafts. They can also be pinned. #4 still may be the most rewarding...  | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I think its going to be much easier to modify the seat. Somewhere on here is a mod to flip the back hooks around so the seat back reclines a bit. I bet that will give you more space than changing the steering column.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i'm runnin a75 chevy van column in my 49,i to suffer from the dickey do diease.i shipprd my column to missouri and had it shortened also had the guy go through the electrics to make sure everything was up to par.he took 3" out of the coloumn and two out of the shaft it was a perfect fit .charged $100.00 plus $20.00 shipping well worth it in my book......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I'm not sure any solution of the 3 will work for long. It is only a matter of time (as we grow) that another cutting and shortning or seat removal etc. will be needed. My advice (no charge and well worth the price)is try number 4. That way you will feel much better, we will have you here on the bolt longer, and your gas milage will improve.
~Jim
| | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I had this problem on my '51 1/2...(I've since lost weight!)...two solutions I used... 1) Moved the whole steering column & box forward on the frame about 2" (didn't hurt the steering geometry) 2) Bought a nice 15" aftermarket wheel from LeCarre. | | |
