1 members (Shade Baby),
109
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 12 New Guy | | New Guy Joined: Jul 2006 Posts: 12 | My '66 K10's last owner was an idiot. As my front drums have 1/8th inch grooves worn into them, and the linings are installed in two different directions. At this point, I'm not sure what went where, other than I know for a fact where all the springs went. Which Direction do the linings go? When I took it apart, the small lining was on the front and the large lining was on the back, but this was on the drivers side, on the passengers side, the small lining was in the back, and the large lining was in the front. The drivers side was more equally worn, as the small one on the back of the passengerside was down to the bare metal. I've read in the book for my Z28 Camaro, and it says that the large lining goes to the back, and the small in the front, but these are for rear drums. I'm not sure if it is the same for front drums or not. BTW ANYONE WHO HAS A '60-'66 K10 WITH YOUR ORIGINAL FRONT AXLE, AND A CRACKED STEERING BOX, I HAVE FOUND A SUITABLE REPLACEMENT THAT WILL ALSO GIVE YOU POWERSTEERING FROM A SAGINAW BRAND BOX.
Chevrolet, An American Revolution. Somethins Wrong Cletus!!!
| | | | | Joined: Jan 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 48 | Large lining faces rear, small lining faces front. You're one up on me, I usually have trouble with fore and aft on the large springs.
Joe -------------------------- '67 Chevy C20 fleetside, 250 inline, 3 on tree, heavy duty clutch and brakes, heater, steel bed floor ----------- "Tighten until the stud snaps, then back off half a turn."
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | the power steering that you are talking about maybe for a 2wd you might want to double check first, before you buy one. i have a 63 k-10 and am putting power steering on it with the help of 456chevy. and he has to fab a braket for the 4x4's thanks mike 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Jul 2006 Posts: 12 New Guy | | New Guy Joined: Jul 2006 Posts: 12 | I've got the power steering conversion done, while retaining my original front axle, and doing nothing more than drilling 3 holes in the frame, and getting a custom pitman arm made. U-Joints in the steering column are also required, but easily done and found. Take a peak under the '76 and lower Dodge 1/2 full sized 4X4 trucks, youll find a Saginaw box thats the same style as the original Sawinaw that Chevy used, only heavier duty and with the addition of a power circuit. And thanks for the info on the brakes, just had to double check.
