| | | Forums66 Topics128,204 Posts1,057,292 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | I don't remember gasoline having a "color" to it. When I drained my tank today this this is what it looked like. Should I worry about the color?  Plan on blowing out the lines, changing the rubber lines and in-line filter. Then get some fresh gas in it for its first start-up since it went from the truck to my garage 6 months ago. Also wondering about the spring tied around the front left motor mount going to the shift linkage (3 on the tree). I'm sure it's not original, just not sure where it should go and how long it should be. Any ideas? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is old gas. You have the procedure downpat. That spring is a clutch pedal return spring. It usually is smaller than that & attaches to a bracket on a oil pan bolt. I can,t make out what that vertcal rod or whatever it is is. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | fredoly,
To my knowledge, gasoline has always had color. This is one way different brands and grades were identified. When I worked for Standard Oil, we actually injected dye into the gas as it was being pumped off the tanker into the storage tanks.
As for the spring...take it off and see why it was there. Good luck.
Stuart | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | old gas, just what wrenchbender ret said 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I can't speak for all states but in Kansas gas isn't clear. Your picture looks like normal 87 octane around here. Premium has a bit of a pink tinge. Having said that, if the gas is six months old & wasn't stabilized you should probably not use it. BTW diesel is colorized too. I don't remember the color but off road diesel that isn't taxed as heavily has a specific color so the LEOs can tell if the driver is cheating or not.
Go get some fresh gas & pour some into a clear container. I'd be really surprised if it's clear. BTW, the 20+ year old gas I drained out of Sweetie was quite red in color, almost totally varnish.
| | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | I have never seen gas that didn't have color to it. I just assumed that the color was normal. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | That spring is either for the brake pedal or the clutch linkage. (keeps the pedal coming back up after you press it down) For either of those, there should be a little bracket bolted to the frame that the spring goes to.
Good luck. | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | Really appreciate the feedback. Now I can get back to work and get it running and on the street. Thanks bolters! | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | My gasoline was twice as dark, with little rust chunks floating freely. Getting new everything. Gas in Nebraska has a little color to it, not quite that dark though. Good luck. Wada | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Dude.. I run gas thru my engines that looked like Killians Red before. Dump some on the ground, drop a match.. if it ignites, it's good.
What you want to watch out for is loose crud in the tank itself clogging up lines.. but i've fired up vehicles that hadn't been run in as many as 15 years just by filling 'em up with some fresh gas, and squirting some fresh gas in the carb to get it going till the fuel pump could fill up the line.
I've been all over the world.. some places the gas is clear.. other places the gas is tinted that same kind of color. Never knew why, and I can't say as tho I ever cared enough to find out why.
Of course, I prefer clear gas.. that way it's easier to tell which can was for the weed whacker and which one was straight gas.
| | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Most all fuels used do have a die put into them. I understand that when fuels are transfered to fuel depots in pipelines a die is added so as to tell when and what type of fuels are present.Computers and persomel then know what tanks to dispence fuels to. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | I've got 5 gallons of 5 year old nasty gas too.. i mix it into my weedwacker gas and occasionally i'll use some to clean parts with.. it will start The Binder, but i dont want to pour it back in the tank.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If I have old gas w/no chunks I feed it into my brown truck a little at a time-that stuff costs too much to waste. Like Fumblin said, if it will burn... | | |
