| | | Forums66 Topics128,078 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 14 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 14 | I am a big fan of the Grills on the 1947-1953 Chevy 3100s. I have the oportunity to buy a 1954. Would it be easy to put a 53 grill on a 54 or would it take a lot of modification? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The fenders on a '54 are a little different to allow room for the parking lights.
I believe swapping the grills is as easy as drilling a few holes, but to make it look right you need to change the fenders too.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Old Sub is right,,youll need to change the fenders. At the top corner of the grille the 47-53 is kinda squared off,,the 54 is rounded,,also theres an indent for the parking lights. Possibly have to change the inner fenders too? Marty | | | | | | Anonymous Unregistered | | Anonymous Unregistered | OH THE PAIN!!! Someone wanting to bastardize a 54 into a 53! Keep it as a 54. Don't ruin it! You have the chance to have a truly unique truck there. Why would you want to make it look like everyone elses?  | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | make it yours! If you wanna put a 47-53 grill in your 54.....GO FOR IT! They look better than the 54's anyway. (but thats just my opinion) You may have to change the fenders too though like earlier posts have said. Otherwise, it could be done with the current fenders, but youre gonna have to do some body work.
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Feb 2006 Posts: 14 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 14 | Other than the fenders and grill what are the major differences between a 53 and a 54? | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | 54 box has squared off tops on the box sides. They are flat on top instead of like a 45 degree angle on the 47-53, the script on the tailgate is different, otherwise, The cab and hood are exactly the same. Plus little things like trim and dash of course are different on a 54
| | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | also see this description for differences from the Jim Carter catalog http://www.oldchevytrucks.biz/catalog1/00004.htm
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Differences in 1/2 ton models - 1954 and earlier:
Different frames.
Different beds.
Different windshields.
Different wiring systems (plastic coated in 1954).
Different front hood emblems.
Different rear lights and rear bumpers (cab models).
Different rear end ratios.
Different rear spring perches.
Different engine lubrication systems.
Different upholstery scheme and exterior paint options.
Different dash boards, gauge clusters, and radio.
More options and accessories in 1954. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I always wanted to build a hot rod using a '54/'55 1st series cab and the earlier grille. I like the one piece curved windshield with the older grille. It's not like you can't put the original grille and fenders back on it if you wanted to...and it won't look like everyone elses either... Here is an example from the member gallery. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'm with Houston54 on this one, have a 53 and wish it was a 54 for several reasons. | | |
