5 members (Joe H, baldeagle, Bill Hanlon, Jon G, Nick in Manitou), 63 guests, and 4 robots.
Topics128,014
Posts1,055,333
Members48,419
#228103 02/25/2007 8:34 PM
O.K.--I know that I have only been restoring one 'bolt over the last two years, but it has been a crash course! (no pun). Anyway, today I saw on E-bay a sheet of metal that is supposed to go under the bed to shield heat from the exhaust pipe. Maybe I have missed something over these months, but I have not seen such an item. Does it ring a bell with anybody? The item number on E-bay is 110095690663 just FYI.
#228104 02/25/2007 8:42 PM
Hey Shmoo,
Just about every major vendor such as Jim Carter, Classic Parts, Chevs of the 40's carries them.
But first check out a couple of 'Bolt sponsors such as American Classic, linked at the top of the page, or check with Mar-K that sponsors the truckbed forum.
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#228105 02/25/2007 9:11 PM
Blue--
Thanks for that info! I went up to Mar-K and found the info and ordered a stainless shield for 7 bucks.
How good is the BOLT!!!!
#228106 02/25/2007 9:26 PM
I've heard of 'em.. don't know if they were factory equipment, i've never seen an 'original' one, but usually by the time I get my eyes on an old truck, the original bed wood is long gone.
I don't guess it would hurt anything to have one on there, but on the same token, I don't think the radiated heat coming off the exhaust pipe poses that much of a threat to the bed wood, either.
#228107 02/25/2007 9:39 PM
Yes, they were original equipment, but usually they're rusted away or the nails that hold them in rusted/fell out. I didn't bother with putting a new one in, although the original was still in place and in relatively good shape. I've still got it somewhere around here. I did re-rout the exhaust to get it away from the wood.
Bill Burmeister
#228108 02/25/2007 10:18 PM
those shields were put on the wood right above where the muffler was, as it's fairly close and does get pretty hot when running a long time .... doubt if it's a "fire hazard" situation, but hard on whatever you use for a wood finish to have it heated that much
#228109 02/25/2007 10:39 PM
red58, that heat shield is on the bed wood where the tailpipe goes over the real axle. At least, that is where is was on my 53!
#228110 02/25/2007 11:16 PM
sounds reasonable grin I was remembering my fleetside, where it may have been misplaced when the wood was changed .... thinkin about it I believe it is over the axle on my panel truck ohwell same principle, the heat affects the finish
#228111 02/25/2007 11:19 PM
I have the original shield on the original wood. It's above the muffler. And the shield and the wood show some heat evidence.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#228112 02/25/2007 11:23 PM
on the 62? maybe they changed things after the AD years - finally gettin it right grin I do think the muffler gets a lot hotter than the tailpipe
#228113 02/25/2007 11:31 PM
Yeah, Mar-K did suggest that maybe two of them could be needed; I only ordered one but plan to do a creeper search after it stops snowing here. Maybe the muffler should be shielded too, since the finish on the new boards is kinda green. Will report the results of my research if the snow ever melts. Shouldn't complain; Oswego got a hundred times more!
#228114 02/25/2007 11:35 PM
My '55 only had 1, and it was where the pipe went over the axle. And it was on the passenger side. Seems the pipe crossed ove to the right on the 3200/3600 that year, don't really know why. The muffler shop special exhaust that was on it was routed wrong anyway, so the shield didn't really do anything.
Bill Burmeister
#228115 02/27/2007 12:32 AM
MY 50 3100 had one over the where the tailpipe crossed over the rear axle. It comes pretty close to the wood at that point. The muffler on that old truck was only slightly larger in diameter to the pipe itself so that wasn't anywhere close to the wood.
