7 members (CuzzFuzz, baldeagle, kades51, frogfarmer, Brian Moore, Hotrod Lincoln, 1 invisible),
33
9
Mod | | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | O.K.--I know that I have only been restoring one 'bolt over the last two years, but it has been a crash course! (no pun). Anyway, today I saw on E-bay a sheet of metal that is supposed to go under the bed to shield heat from the exhaust pipe. Maybe I have missed something over these months, but I have not seen such an item. Does it ring a bell with anybody? The item number on E-bay is 110095690663 just FYI. | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Hey Shmoo, Just about every major vendor such as Jim Carter, Classic Parts, Chevs of the 40's carries them.
But first check out a couple of 'Bolt sponsors such as American Classic, linked at the top of the page, or check with Mar-K that sponsors the truckbed forum.
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | Blue-- Thanks for that info! I went up to Mar-K and found the info and ordered a stainless shield for 7 bucks. How good is the BOLT!!!! | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I've heard of 'em.. don't know if they were factory equipment, i've never seen an 'original' one, but usually by the time I get my eyes on an old truck, the original bed wood is long gone.
I don't guess it would hurt anything to have one on there, but on the same token, I don't think the radiated heat coming off the exhaust pipe poses that much of a threat to the bed wood, either.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, they were original equipment, but usually they're rusted away or the nails that hold them in rusted/fell out. I didn't bother with putting a new one in, although the original was still in place and in relatively good shape. I've still got it somewhere around here. I did re-rout the exhaust to get it away from the wood.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | those shields were put on the wood right above where the muffler was, as it's fairly close and does get pretty hot when running a long time .... doubt if it's a "fire hazard" situation, but hard on whatever you use for a wood finish to have it heated that much
Bill | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | red58, that heat shield is on the bed wood where the tailpipe goes over the real axle. At least, that is where is was on my 53! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds reasonable  I was remembering my fleetside, where it may have been misplaced when the wood was changed .... thinkin about it I believe it is over the axle on my panel truck  same principle, the heat affects the finish Bill | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I have the original shield on the original wood. It's above the muffler. And the shield and the wood show some heat evidence. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | on the 62? maybe they changed things after the AD years - finally gettin it right  I do think the muffler gets a lot hotter than the tailpipe Bill | | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | Yeah, Mar-K did suggest that maybe two of them could be needed; I only ordered one but plan to do a creeper search after it stops snowing here. Maybe the muffler should be shielded too, since the finish on the new boards is kinda green. Will report the results of my research if the snow ever melts. Shouldn't complain; Oswego got a hundred times more! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | My '55 only had 1, and it was where the pipe went over the axle. And it was on the passenger side. Seems the pipe crossed ove to the right on the 3200/3600 that year, don't really know why. The muffler shop special exhaust that was on it was routed wrong anyway, so the shield didn't really do anything.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | MY 50 3100 had one over the where the tailpipe crossed over the rear axle. It comes pretty close to the wood at that point. The muffler on that old truck was only slightly larger in diameter to the pipe itself so that wasn't anywhere close to the wood. | | |
