1 members (Peggy M),
39
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | I have a 235 engine and i keep reading about this pointer and ball indicator, mine does not have one! whi is that? I need help with my problem with a misfire on this engine, the engine has not been in service since 1979 and when i bought the truck i replaced all tune up parts, plugs, wires, cap, points, rotor, coil, rebuilt carb, drained gas tank, cleaned it, new fuel filter, replaced generator with alternator one wire, adjusted all rockers to .006 intake and .016 exhaust hot. the new plugs get black soot, i will have to check carb settings. to do this tell me if i turn the 1 bbl carb screw in it will be running rich? right ( i am not sure ) also i have not driven it on the road yet and it is just idleing and reving so that could also add to t he black soot?! i checked the points gap .016 and cant get this misfire to smooth out, i switched plugs the other day and it ran sweet smooth for about a minute then the exhaust started bobbing again i cant figure it out for nothing i am running some gas treatment thru it, i hope that gets rid of whatever it may be , i am thinking that i have some garbage stuck to a valve or something.. thanks for your help jeff | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | | | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | nnew wires aswell
its wierd i have tried everything... | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | superpieboy,
The pointer is a sharp little nail located in the hole directly above the starter on the face of the bellhousing. The ball is a embedded BB in the back of the flywheel. As the engine runs, you can look through that hole and see the flywheel whizz by. If you had super pupils, you would spot the little ball as it passed through this 'viewing window'.
The ball, which is usually pretty dirty and needs to be cleaned up and highlighted with yellow marker or such, is the timing mark you align with the little nail/pointer hanging down.
This is all done with a timing light attached to number one plug wire. Rotating the distributor will parade that ball to be illuminated BEFORE or AFTER little pointer.
Screwing the idle fuel mixture screw IN will lean the idle out, eventually killing the engine. A ballpark setting is 1 1/2 turns OUT from all the way seated.
Most of your problems sound like a gunked up carburetor...maybe a stuck or sticking powervalve. Valves that are sticky will hang and cause a miss too. Fiddle with it some more, it sounds like you are pretty sharp on these things. Good luck.
Stuart | | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | i rebuilt the carb, i am thinking sticking valve and or gunk on valve seat, i am going to leave it be for now and when its on the road i will run it for a few days and see if it clears out....
so the pointer and ball timing thingie is on the bell housing, i swear i have looked several times for this thing....
jeff | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | superpieboy,
The carburetor base has a small hole in it the reads engine vacuum. The base gasket has a small notch in it that allows this hole to remain uncovered and must be installed correctly for this to happen. If it is covered, the carburetor thinks it is pulling a big trailer up a steep hill and responds accordingly.
If you stick your index finger into the viewing hole, I will guarantee that you will find the sharp little pointer. The BB is tougher to locate. Have Band-Aids standing by!
Stuart | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I finally scraped enough gunk off my engine to find the hole, but I never did see the ball on the flywheel.. so I had to use the piston and valve positions to determine where the rotor was supposed to be.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Fumblin46,
I don't remember if I did this on a stovebolt or not, but sticking a thin, long screwdriver into #1 plug hole will give you a great reading on the piston location as the screwdriver rides it up to TDC.
Stuart | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | The easiest way to find the "ball" in the flywheel is to remove the spark plugs and the tin flywheel cover from the bottom of the clutch/flywheel. You can now turn the flywheel untill you find the "ball" (some engines have a triangle shaped mark instead of a ball) located on the front side of the flywheel. Put a white paint mark on it and also on the pointer so they can be seen easily with the timing light. Timing is easy from this point once you are certain that you have #1 cylinder set on the compression stroke. Good luck with the truck.
Carl
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
| | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | i will check this carb base out and see if its on right, although i did start the truck this morning and it ran without the before stated miss! its weird all the same, i put a rather concentrated amount of fuel cleaner into the gas in hopes that it will clear out what ever is happening, i am loving this straight six engine, cant wait to drive the ice cream truck.
jeff | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Have you done a compression check? A burnt valve or blown head gasket will make it pop back thru the carb,,misfire,etc... Marty | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The black soot on the plugs indicates you're running too rich. One thing I didn't see in your list of parts replaced was a new air filter. Check your filter, make sure it's clean, also check the choke setting. If It's manual make sure it's opening and closing properly, if automatic, make sure is opens all the way as the engine warms up. I think a 'bolt ice cream truck is cool!! | | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | the way that the air breather set in this engine compartment was by a tube that ran from the carb to the breather which sat on the distributor side of the engine, i have the breather but not the tube, so at this time it is free breathing...
manual choke open all the way up,
i probable need too check the adjustments on the carb,,
correct me here turning the carb screw in will lean out the mixture??????
have not done a compression test, almost afraid to after this engine set for 29 years, i am running some engine cleaner thru it right now that is suppose to free things up....
i have not driven it on the streeet yet just idle and revs everyday or so. | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | Turning the screw in leans out the mixture, yes. When the screw is turned in you are lessening the gasoline flow so there is more air than gas in the mixture = a leaner mixture.
Carl
| | | | | Joined: Jan 2007 Posts: 50 Member | | Member Joined: Jan 2007 Posts: 50 | If it runs well enough to drive then take it out on the road. A driveway reve tune is tough to pin point prob. Take phone with you or tool box.----- I had a defective new coil truck ran good in yard ,when out on road as coil heated up it stumbled enough to blacken plugs. Bring it home clean plugs ,monkey with carb.(now i know carb was fine)start up good and do it again.First bad coil in my life.This one had me chasing my tail because I should have stepped back and thought it thru.
restoring a 1946 coe wrecker.
| | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | i am pondering a rebuild!!!! or maybe i need a lil patience, this 235 does not have an oil filter, first time for me of not seeing one on an engine.
it smokes white smoke when rpm's come down after you rev it, and when it stammers a poof of smoke ect ect
how much is a basic rebuild?
or maybe i will wait till ihave all lights in and legal i will drive it and see what happens.
pieboy | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Black smoke=gas Blue smoke=oil White smoke=maybe water in combustion chamber?? If it only has white smoke on start up its condensation/steam and should clear up. | | |
