5 members (Peggy M, klhansen, TooMany2count, Millenimech, dwreills), 33 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#227810 02/21/2007 9:45 PM
Apprentice
Apprentice
Hey guys i posted this in the driveline and engine shop but did not get any replies. So do any of you have a book that might help me find out what the factory timing is for my 65 chevy truck. thanks guys justin
1965 Chevy C-10
All Original
#227811 02/21/2007 10:07 PM
Justin,
My old bible says for your 250, the timing is 6&deg before TDC.
Stuart
#227812 02/22/2007 3:06 AM
Apprentice
Apprentice
My truck has a 230 in it. I think it should be TDC but need to confirm. Any help would be appreciated. Thanks, Jusin
1965 Chevy C-10
All Original
#227813 02/22/2007 3:26 AM
Justin,
I guess I need to clean my glasses...sorry. I do know that the setting for the 250 is 6&deg BTDC, so my guess is that your engine would be the same.
I will check my Motors Manual when I get back to work and try to verify the setting.
Sorry for my confusing info.
Stuart
#227814 02/22/2007 3:41 AM
If I remember correctly, a 230 is either 4 degrees BTDC or 6 degrees BTDC. The 250 is the big brother of the 230.
#227815 02/22/2007 5:16 AM
It is indeed 4 degrees BTDC.
#227816 02/22/2007 3:31 PM
Justin,
In an attempt to split some hairs, my reference shows 6&deg BTDC UNLESS you have a AIR pump, then is shows 4&deg BTDC. It's OK to customize these figures for maximum 'poop' without negative side effects...overheating or pinging.
The backyard credo is 'more is better', within reason.
I don't think I know of any engine that is timed to fire at TDC.
Stuart
