1 members (Rusty Heaps),
114
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 34 Apprentice | | Apprentice Joined: Feb 2007 Posts: 34 | Hey guys i posted this in the driveline and engine shop but did not get any replies. So do any of you have a book that might help me find out what the factory timing is for my 65 chevy truck. thanks guys justin | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Justin,
My old bible says for your 250, the timing is 6° before TDC.
Stuart | | | | | Joined: Feb 2007 Posts: 34 Apprentice | | Apprentice Joined: Feb 2007 Posts: 34 | My truck has a 230 in it. I think it should be TDC but need to confirm. Any help would be appreciated. Thanks, Jusin | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Justin,
I guess I need to clean my glasses...sorry. I do know that the setting for the 250 is 6° BTDC, so my guess is that your engine would be the same.
I will check my Motors Manual when I get back to work and try to verify the setting.
Sorry for my confusing info.
Stuart | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | If I remember correctly, a 230 is either 4 degrees BTDC or 6 degrees BTDC. The 250 is the big brother of the 230. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | It is indeed 4 degrees BTDC. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Justin,
In an attempt to split some hairs, my reference shows 6° BTDC UNLESS you have a AIR pump, then is shows 4° BTDC. It's OK to customize these figures for maximum 'poop' without negative side effects...overheating or pinging.
The backyard credo is 'more is better', within reason.
I don't think I know of any engine that is timed to fire at TDC.
Stuart | | |
