9 members (TexasJim50, klhansen, Gdads51, J Lucas, Stovebolt48, Hotrod Lincoln, tclederman, GusG, Peggy M),
115
Mod | | | Forums66 Topics128,089 Posts1,056,422 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22777 02/25/2004 8:35 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Since I know little and more like a -10 about transmissions, I hope someone can help me identify these trannys-The only tranny I have ever rebuilt was a T-90 in a Willys Jeep about 30 years ago. The folks that rented from us some years back left these two trannys here. They were hotrodders and these trannies are for chevys. I think the first one is a T-5 but I don't know what year or if it is even worth anything. The second one I was told is a Muncie 4 speed (rock-crusher). The muncie doesn't have a side plate and the gear that is at the far rear of the tranny is totally lunched so is the gear corresponding to it on the bottom. But the rest of the gears look good to the eye. What are these trannies and are they worth anything? T-5(?) [img] http://photo.starblvd.net/cindyspics/3-3-5-1080917511?m=1&pg=2&ro=2&co=4[/img] Muncie 4 speed [img] http://photo.starblvd.net/cindyspics/3-3-4-1080941731?m=1&pg=2&ro=2&co=3[/img]
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#22779 02/25/2004 9:52 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | That first tranny MAY be a T-56 (Camaro 6 speed) but I can't find any good pictures from the same angle. If it is it is worth some big money if it is in good condition. Rebuilt ones are about $2500.
#22780 02/25/2004 10:21 PM | Joined: Feb 2004 Posts: 29,827 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,827 | A Muncie without a shift plate, and with a trashed cluster gear and at least one output gear damaged is just one step above a boat anchor. If you decide to repair it, have it completely disassembled, and check the case closely for cracks. They're not the world's strongest design, and one that's been hand grenaded is likely to have some hidden problems, too. Jerry
#22781 02/25/2004 10:35 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The so called Rock Crusher has a 22 degree angle on the gear teeth, that Muncie gearset look like the regular 45 degree angle gear set. At first I thought the other trans was a T-5, but maybe not, who knows, may some Japanese unit. T-56 looks like this supposedly; [img] http://www.hpsalvage.com/mtranni.jpg[/img] | | |
#22782 02/29/2004 1:28 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Oly, the other tranny you show, not the Muncie, is a Borg Warner T-50.According to what I found, it was used in H body (Monza types) in the late 70's. T-50 | | |
#22783 03/28/2006 7:28 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | The first tranny is a world-class t-5.
Look for some casting numbers on the main box, a green and white sticker or an aluminum tag. The most useful would be the sticker or tag. What you are looking for is the first four numbers, if they are 1352, its a T-5. If you've got a tag or sticker, the next numbers will help you decode what it was used in and what gear ratios it has.
That first tranny has a 'short throw shifter' mounted in place of the stock shifter. Those things sell used on e-bay for about $75 and new closer to $200.
Run it through the gears and pop the cover on the box and have a look at the syncros and fluid to see what sort of shape its in!
By the way, it looks like its got a ten spline input shaft from a jeep, which might work just fine with your stock clutch.
