1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 74 | were can i find these? rubber gromets that acually fit under radiator. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | look at this page , should have it all ... maybe RDR-24 is what ya want? Bill | | | | | Joined: Jan 2006 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 74 | Thanks red58 it was acually rmp63 but at least I found it. | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | a piece of old conveyor or bailer belting works well tomake your own,
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | My preference.....Truck MUD FLAPS....they cut like butter with a sabre saw (or hacksaw), are available in a variety of thicknesses, and are just laying around on our highways waiting to be scoffed up by some resourceful bolter.
Keep your eyes open....you'd be amazed how many uses they have!!! Save a few bucks too!
Dave | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Bicycle tire inner tube pieces folded over. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Anyone have the correct mounting details for the radiator support on an AD truck?
Starting from the top here is how I am envisioning it, how should it be?
support is tapped 3/8-16 some sort of rubber pad cross-member rubber pad again flat washer lock washer bolt
Thanks, Grigg
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Grigg , Ya got it right as far as assembly , I used a pc of thick belting from work on mine, a chunk of belting makes lottsa spacers . ya need a chunk send me a PM . Tim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks Tim, I already have plenty of new 3/16" or 1/4" belting from a round bailer, should be just perfect.
Grigg | | |
