| | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | Both my trucks have the original 4-speed trannys. Question is, are the trannys geared the same in the 1/2 ton and the 3/4 ton? As the 3/4 ton ('58) has the tighter/better tranny I am thinking on swapping it into the 1/2 ton ('59).
Carl
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, they'll have the same ratios, but if you don't really need that granny low, you could leave the "working" truck alone and find a 3spd for the light truck with about the same effort as pulling both! Bill | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | Bill....I like the 4-speed. Dont need the granny gear though in the 1/2 ton, would gladly trade it for OD. What about a T5? Would that be a better choice?
Carl
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | could work, but I'm more into same-era changes, wouldn't use a T5 - an original 55-70ish 3spd OD would be trick - I've got a pair of the early ones I plan on using
OTOH because you've got floor shift now, you might look into the NewProcess A833, an OD 4spd that was used on trucks [70s-80s?], heavier duty and good ratios - search it here, been discussed a few times
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | 1/2-ton with a six and a T-5 is a workable and popular swap. Be sure to search and read through the issues people have needed to deal with in making the swap before starting.
Aside from being a different era the shifter isn't really in the right spot so that might cause some look and ergonomic issues.
My '55 1st 1/2-ton (Suburban) has an SM420 and I just drive it like a 3-speed and get along fine that way. But I've changed the rear to one with 3.08 gears so highway speed isn't a problem. I sometimes think it would be more pleasant to drive with a car type 4-speed like a Saginaw or perhaps a T-5.
I also have a 4-speed car with OD that I drive nearly every day and sometimes think the control a 5- or 6-speed offers would be more fun. Its not that the OD is bad as much as it often wants to shift at times when I would rather it didn't. I may someday change it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | What about the rear end gear swap kit from Patrick's? Would that do the trick for him?
He wouldn't have to swap any trannies, just change out the stuff in the rear axle and his first gear becomes a real first gear and his 4th becomes a an OD. Of course, the 1st gear still won't be synchro...
Just throwing out ideas.
r, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | It sounds to me like his original question was whether the transmissions could be swapped,because the one in the truck he didn't drive often was better than his driver. The answer to that Question is "Yes-it'll work fine." Now,my question is Is it possible/desirable to use a later GM full sized 5 speed overdrive in a Stovebolt? I'm guessing there's some wierd thing about 'em that makes 'em un-swapable,because I never hear 'em mentioned around here. Speed | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Now,my question is Is it possible/desirable to use a later GM full sized 5 speed overdrive in a Stovebolt? I'm guessing there's some wierd thing about 'em that makes 'em un-swapable,because I never hear 'em mentioned around here.
They can be used if it has a v-8. They will not fit the old stovebolt 6,s. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Originally posted by Wrenchbender Ret.: They can be used if it has a v-8. They will not fit the old stovebolt 6,s. You can get an adapter from advance adapters to stick a dodge nv4500 where your SM420 was behind a straight 6. | | |
