| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | The driver's side window regulator won't budge. I can see the scissor mechanism wiggling a bit, but it won't lower the window.. This is on my '64. I was going to remove the regulator screws, then decided to ask here before breaking the glass. How should I approach pulling the mechanism out? The regulator shaft has excessive play in it. Are there bushings available, or should I plan to turn one? Better to buy a regulator? LMC Truck?
Thanks!
CJ | | | | | Joined: Apr 2006 Posts: 18 Apprentice | | Apprentice Joined: Apr 2006 Posts: 18 | Try taping the window into place first so it doesn't fall & break. Then pull all the screws to find the problem.Most regulator components are available seperatly from classic parts of america. | | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | That sounds reasonable! I'll scoot out there as soon as the latest rain squall finishes floating my yard ornaments and find out what happened. Duct Tape, the universal tool... CJ | | |
