5 members (Bisbee, LuckyLee, D B Cooper, Otto Skorzeny, Robert Crandall), 53 guests, and 2 robots.
Topics128,131
Posts1,056,723
Members48,454
I would like to install my double action fuel/vacuum pump so my wipers don't slow down so drastically. How are the vacuum lines routed? Is the engine vacuum still used? Any advice or comments are appreciated. Thanks, Possum
Ex Hall Monitor
Ex Hall Monitor
I've considered doing the same with my 38. I've not seen any "official" instructions but I would imagine the vacuum line would just route the path that would keep it out of the way. I would route it through the firewall hole the current line occupies. I can't imagine the engine vacuum being used for the wipers anymore. I'm sure that if I'm wrong someone will correct me. grin
The double action fuel pump has two diaphragms, one pumps gasoline the other supplements the vacuum. The exit line from the vacuum side goes to manifold vacuum. The other line goes to the wiper motor.
"It ain't a truck if you can't hose out the cab."
Riding in the Passing Lane
You still need to use the manifold vacuum also. The pump is an auxilary. Plumb it like Chester says.
1972 Chevy c10 Cheyenne Super
46possum,
Enclosed is a great link that even has pictures. I have seen questions on this before, and it seems there are several different pumps and a few varying ways to hook them up. Take a look!
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=003936#000000
Stuart
There are diagrams in the factory assembly manual. Should be about the same for all years.
My Trucks
Stuff I Collect
Ex Hall Monitor
Ex Hall Monitor
See, I told ya I'd get corrected if I was wrong. grin wink
Another option is to install a vacuum tank in the line to the wipers. It needs to have a one-way valve so it doesn't bleed down. There are lots of them at the junkyards, most all modern cars have them. Only problem is finding one that looks like it belongs in an old truck.
Fred
52 3600
69 C-10
V
V Offline
Hey I have one of those double action fuel/wipers pumps in my garage that has never been used. If anyone wants it, let me know.
I bought the wrong one and had it taken off my truck before I put gas in it. You can see it in the picture link below as well as the new one single action I bouight to replace the one I'll be letting go. I made a mistake so somebody might as well put it thier stovebolt.
