3 members (oldsteve, doyle1950, frogfarmer), 167 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
#226491 02/06/2007 3:15 AM
Junior Member
Junior Member
Putting a tach in also want to fill the other side with a clock.Anyone knows what clock would fit? Thanks
#226492 02/06/2007 3:32 AM
the factory clocks were in a pod in the center of the dash the other side of the tach side sometimes was a vacuum gauge jus my 2 cents
#226493 02/06/2007 8:39 AM
I have a dash gauge cluster for a '64-'66 Chevy truck with a clock in the left window of the cluster. I believe the previous owner told me the clock came from a late 70's Impala. I do not have a photo of the cluster on my photo web host, however I will take a few and post on this topic. The clock looks right at home, since the lettering size, shape and style is very similar to the factory markings on the other gauges.
A clock in this position is an excellent way to finish off the factory dash cluster, coupled with a factory tach in the right window. It beats the pants of off a tach hose clamped to the steering column and a clock stuck to the dash. I will follow with some good pictures of this application.
Tony
#226494 02/07/2007 1:43 AM
Socket Breaker
Socket Breaker
this clock was in my truck when I bought it:
http://matraca.home.mindspring.com/img01202006/03.html
no idea what it is out of tho'.
I've been told that it looks mid 1960's chevy car tho.
-W
#226495 02/07/2007 6:40 AM
Z
Z Offline
ive seen people use 60s nova clocks.
