7 members (Southerntruck, J Lucas, 49nut, moparguy, ndkid275, Barry Martak, 1 invisible), 80 guests, and 3 robots.
Topics128,133
Posts1,056,398
Members48,441
Anonymous
Unregistered
Anonymous
Unregistered
I was able to finish rebuilding the vent window assemblies on my 54 this past weekend and tried to document the process in order to help someone else who may want to enjoy this as much as I did.
If you have to do this on your project soon, I would suggest making a print out of these steps and saving it for your future use.
My disk capacity on picture trail is maxed out so I do not know how long this and the bear claw latch install album will be retained.
I hope this helps.
http://www.picturetrail.com/gallery/view?p=999&gid=15107151&uid=2902753
Thanks H54.
I am following right behind with my 54. I just go her repainted blue.
Tim
53 3100
1929 Ford Roadster Pickup
1934 Ford Pickup
68 Plymouth Satellite RR Clone 2 Door
My Fleet
Hi Houston, I just tried to print this excellent article/pictures and ran into a request for a password-- what did I do wrong?
Glenn
We had a problem Houston...
We don't anymore. Thanks for this very useful info. I have saved it on computer and printed it for future use. It will be a few months before I'll be ready to tackle the vents but when I do I believe it won't be nearly as dificult as it would have been had you not shared this with us.
Thanks again.
~Jim
Thanks Houston54! This is down the road a little ways for me but I have printed it out for when the time comes. Your pictures explain a lot better than a million words.
Anonymous
Unregistered
Anonymous
Unregistered
Grandpa - Do not use the Picture Trail print option. Instead use your file command in the top command line and then select print. That should do it.
By the way - Welcome to the Stovebolt.
Socket Breaker
Socket Breaker
Houston54 - that is great stuff there. Thanks for going to the trouble and for sharing.
I think that would make a great tech tip.
-W
Authorized Pest
Authorized Pest
Houston,
I'll stuff this in my pending file and try to pull these off. Will you help put the Tech Tip together. Then you can pull them off your Picture Trail and then just send folks to the Tech Tips section. And THEN start on your next one!!
Peggy
~ Peggy M
1949 Chevrolet 3804
Thanks H54 this had me worried
Ridge dweller
