| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | I was able to finish rebuilding the vent window assemblies on my 54 this past weekend and tried to document the process in order to help someone else who may want to enjoy this as much as I did. If you have to do this on your project soon, I would suggest making a print out of these steps and saving it for your future use. My disk capacity on picture trail is maxed out so I do not know how long this and the bear claw latch install album will be retained. I hope this helps. http://www.picturetrail.com/gallery/view?p=999&gid=15107151&uid=2902753 | | | | | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | Thanks H54.
I am following right behind with my 54. I just go her repainted blue.
Tim
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
| | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Hi Houston, I just tried to print this excellent article/pictures and ran into a request for a password-- what did I do wrong? Glenn | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | We had a problem Houston... We don't anymore. Thanks for this very useful info. I have saved it on computer and printed it for future use. It will be a few months before I'll be ready to tackle the vents but when I do I believe it won't be nearly as dificult as it would have been had you not shared this with us. Thanks again.
~Jim
| | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Thanks Houston54! This is down the road a little ways for me but I have printed it out for when the time comes. Your pictures explain a lot better than a million words. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Grandpa - Do not use the Picture Trail print option. Instead use your file command in the top command line and then select print. That should do it.
By the way - Welcome to the Stovebolt. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Houston54 - that is great stuff there. Thanks for going to the trouble and for sharing.
I think that would make a great tech tip.
-W | | | | | Joined: Apr 2004 Posts: 5,078 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,078 | Houston,
I'll stuff this in my pending file and try to pull these off. Will you help put the Tech Tip together. Then you can pull them off your Picture Trail and then just send folks to the Tech Tips section. And THEN start on your next one!!
Thanks, Peggy
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | Thanks H54 this had me worried
Ridge dweller
